Question about Dell Inspiron 9400 Notebook
Wifi light is off
I got a dell 9400 and for somereason the wifi light went off how do i get it back on
  • Dell Master
  • 1,183 Answers
If you put the computer in heibernate or standy and after which the light did not come on , try restarting the syetm.
If still no go try pressing the FN +f2 key to enable wifi
If still no go try system restore
Posted on Apr 14, 2008
Charging light is flashing
There are two possible causes for this issue:
1) Your dell 9400 charger is malfunction
2) Your laptop dc power jack is loose or dead
Possible troubleshooting step:
1) Borrow a compatible dell charger to plug in your laptop, if it works without any issue, it means your dell inspiron 9400 adapter need to be replaced.
2) If the compatible dell 9400 charger won't work normally, the problem may lie in your dc power jack.
Hope this will help.
Jan 07, 2013 | Dell Inspiron 9400 Notebook
How do i turn on my wireless capability for a dell inspirion 9400 without using the fn and f2 buttons because the f2 button dose not work
Click start then type Device Manager in the little window. Go to networks adapters click the square or triangle beside it. Right click on the one that says wireless whithin the description and then click ENABLE if this does not work your wifi card is bad. You can purchase an aftermarket really cheap
Nov 12, 2011 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 laptop display problem
First power the system on using Fn+Power and see if the diags run and you have video. If you have video in the diagnostics, then I'd suspect the video card as the failure point.
Also connect an external monitor and press Fn + F8 to activate the VGA port If you get video on an external monitor, I'd suspect the LCD as the failure point.
Dec 26, 2009 | Dell Inspiron 9400 Notebook
Cannot connect directly with ethernet cable or using pre installed wifi card wireless or using netgear wirless on my inspirion 9400 with vista home premium
Windows Vista has always had a prob with netgear.
If you get a free upgrade to 7 (on microsofts web site) then the prob will be solved.
Dec 15, 2009 | Dell Inspiron 9400 Notebook
Can't activate wifi key on inspiron 9400. fn f2
Try to uninstall then re-install the Dell Quickset from the Drivers and utilities disc.
Oct 29, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 display
you may have damaged the screen in which case theres not much more you can do then replace it.if its a new labtop it may be still under warrenty in which case get back to dell.
Mar 22, 2009 | Dell Inspiron 9400 Notebook
Dell 9400 Won't Start
sounds like bad motherboard/power supply. Just to be sure though have you upgraded the ram? If you have more then one memory chip try siwtching out each one and seeing if it's boot farther. It's possible a dimm went bad or the port it's in went bad. Otherwise motherboard/powersupply
Dec 08, 2008 | Dell Inspiron 9400 Notebook
Wi fi light off
Hello Lisa
(01) Is the switch for your WiFi radio in the ON position?
(02) If it is, then it's possible your WiFi connection is (in your operating system) disabled or missing.
(03) If your operating system is Windows Vista, please, go HERE to learn how to access your network connections.
(04) If your operating system is Windows XP
(a) Click on START
(b) Click on NETWORK CONNECTIONS
(05) In either case, make sure your wireless connection is showing there.
(06) If your wireless connection is showing in your network connections, it is likely disabled. In that case, right click on it and choose ENABLE.
(07) Now, let's see if your WiFi LED lights back up for you.
(08) If it doesn't or if there was not a wireless connection in your network connections, please, post back here and let us know. We'll work w/ you to determine why it's missing.
Thank you,
BJ @:)
Apr 14, 2008 | Dell Inspiron 9400 Notebook
i suggest that you should replace the battery because batterey may be faulty take it down to your nearest pc repair shop
Jan 21, 2008 | Dell Inspiron 9400 Notebook
Dell Inspiron 9400 Notebook Logo
151 people viewed this question
Alun Cox
