Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Airwave XM2go It stays at channel one and refuses to move.
  • 3,037 Answers
1. Purchase or borrow a lens cleaner disc and try it first. You can find these things really cheap at any large department store. They usually get the job done well. However, you may need to clean the lens manually if the store-bought cleaner fails.
2. Remove the outer casing of the DVD player. Remove the screws that mount the top casing onto the bottom of the DVD player and slide the top casing off. This will expose the DVD deck, which houses the laser pickup lens.
3. Find the lens. The lens will be glass and under the DVD clamp. The lens will probably have a blue tint to it. If you are having trouble finding the lens, you could shine a light on the components and watch for the reflection.
4. Use a cotton swab and some isopropyl alcohol to gently wipe the lens. Just a quick scrub will do. Dry the laser pickup lens with the other end of the swab.
5. Give the lens a few seconds to dry and replace the covering of the DVD player. Test the efficiency of the player. If necessary, repeat the process.
Let me know if this doesn't work and we can try other options to get it working.
Thank you for using Fixya and Good luck.
Posted on Apr 14, 2008
  • Benjamin Patri
    Benjamin Patri Apr 14, 2008
    I am so sorry about the comment above, that was for a different asker and I misclicked the link. I will post a solution for you in a second.
  • Benjamin Patri
    I would first try removing all power from the radio and see if it will reset itself. If it doesn't or if you tried that already please let me know so that I can understand the situation better.
    Also how long have you had this device? Thank you.
    Genius:
  • 1,665 Answers
It seems key problem
I cannot find a home docking station for my Pioneer Airware radio. Do you have any suggestions other than E-Bay? Thanks.
http://parts.pioneerelectronics.com/part.asp?productNum=XMTSE-XMPIH-01
$53.50 retail from pioneer. Any XM2GO dock should work, there are a few home docks on ebay now. You may need to modify it so it can fit your radio, but the pins are all the same.
Dec 28, 2010 | Pioneer AirWave XM2Go Satellite Radio...
I would like to connect my antenna directly to my XM2GO unit without the docking station. Where can I find an adapter?
Simple. Go to http://xmfanstore.com , click on "Antennas and Extensions" under "Shop Categories" on the left most side of the site; there you will find "XMFanStore XM2go Direct Connect Antenna Adapter" .
It plugs into the SIDE antenna port of your XM unit and you plug the antenna into that.
This URL MAY be a shortcut:
http://store.xmfanstore.com/directconnect.html
May 27, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Does this device charge using a usb cord?
No, you cannot charge the AirWave with a USB, you CAN charge a SkyFi3 only with a USB, but the AirWave (all XM2Go clones) require a 5Volt 2000ma (2A) power supply either a 'wall wart' or cigarette lighter plug.
Jan 12, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Airwave won't power up!
Remove back cover. Plug DC adapter into the bottom of the radio. Use an extra small paperclip or pin to push the 'reset' button just to the left of the white battery. Report back on progress.
Aug 29, 2009 | Pioneer AirWave XM2Go Satellite Radio...
How to unlock radio
center button needed to be held for 10 sec.
Jul 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer xm2go power surge
I have the same problem with my XM2Go. The screen is blank. I ordered a replacement battery but it still doesn't work.
I could really use some help.
Vince
Mar 18, 2008 | Pioneer AirWave XM2Go Satellite Radio...
Suddenly cannot tune
Reset everthing in the menu. Mine does this every few months or so. I scroll thru the menu option until a come to a reset thing.
Dec 18, 2007 | Pioneer AirWave XM2Go Satellite Radio...
Xm2go
It occured to me after plugging it into the car adapter and turning on the car ignition. I ended up sending the unit to Panasonic and they sent me another. This must be a known issue.
Aug 10, 2007 | Pioneer AirWave XM2Go Satellite Radio...
XM 2 GO Not Playing
I had the same problem. I had to reset (use a paper clip into the RESET hole under the battery cover ( or pull out the battery for a a couple of minutes). Then, after recording some songs, I switched over MYXM and then began rotating the channel selector dial. The volume indicator arrow moved off zero and began advancing up the volume scale. I kept doing it until it about half way and my sound was back.
Nov 21, 2006 | Pioneer AirWave XM2Go Satellite Radio...
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
52 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
