Question about Freezers
Ocean Integrated Fridge Freezer manual. Type AMP6824
I would like to get hold of a wiring diagram for the above unit. A service manual would I am sure include a diagram but any publication would be fine. The Ocean UK contact Number may also help.
Many thanks.
Regards. John Hebard.
  • jonheb Apr 25, 2008
    Thanks for your response. Ocean Combi Fridge-Freezer. Type 0730. Modele Number APM6824. I had the compressor replaced some time ago and since then the unit operates all the time. I have replaced the thermostat but it is still on all the time. I need a wiring diagram to see if when it was repaired the wiring was replace in the incorect order.
    Regards. John Hebard..
  • William Borgeson
    William Borgeson May 11, 2010
    If you could, look up the item name and number and then maybe i could help you. (I can't see the topic name.
Is the temperature No. 1 the coldest or No. 9 the coldest?
Posted on Jun 04, 2011
  • 828 Answers
Problem could be associated with the system refrigerant charge. This could be ether an overcharge which would be indicated by frost on the larger line coming back to the compressor, or an undercharge which would cause a continuous run condition. Or the soldered joints where the compressor was replaced could be leaking which would be indicated by oil signs at the point of the leak.
Posted on May 16, 2008
Neff fridge/freezer has stopped cooling
pull the unit from the wall, remove the bottom back panel , see if the small fan is working ,if the fan is , there's probally alot of dust back there,unplug the fridg. and vacuum the area real good,use a flash light to make sure you get it all, if the fan is not working and the compressor is running the fan is the problem ,the fan keeps the compressor and coils cool so the freon can cool down so the unit works like it should,if the freon is hot ,the air the fridg.will be blowing will be hot. this should fix your problem, and YES its worth fixing.alittle p.m.saves alot of $$$$$$$$$
Dec 03, 2013 | Neff Freezers
Ocean Frost Free dial keeps going inro Red/Black & we have no Manual
Hi clarry441,
I would like to clarify if what is the brand, type and model name of your unit?
Thank you for using FixYa.
Jun 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Replaced gasket twice; still ices up around door.
If you replaced your door gasket and your absolutely sure that its sealing properly, then it might not be coming from your door. Ice builds up when warm air enters the fridge and the condensation freezes inside the freezer. The biggest suspect for warm air entering into the fridge is a faulty door gasket. However there can be another cause. If you remove the back panel of your freezer you should be exposed with the wires that come into the freezer and power the different components inside. The entrance point were the wires come in is insulated with a type of clay that prevents moisture from entering. However if this clay becomes loose it is possible for moisture to enter and start icing up. If you can remove the panel yourself safely without hurting yourself or damaging the fridge i recommand trying this first. If you don't feel comfortable doing this i recommand having a service technician taking a look at it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
Oct 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
I need to replace my thermostat on my ge chest freezer model #fcm7sudww, I lost the wiring diagram and I need help to rewire. Thanks
Wiring diagram of the chest freezer turned into chest fridge. The junction box is not required if all connections are made inside the fridge service compartment. Active (A) connection passes via latching relay terminals
inside the thermostat.
Additional information can find HERE.
Hope helps; tell us news.
Aug 05, 2010 | General Electric Chest Freezer FCM5SU
Weve lost the instruction manual for our Hotpoint Fridge-Freezer
Sorry, no secret. The fan wasnt working so we called an engineer who bypassed a sensor. Now it works perfectly again.
Mar 22, 2009 | Bosch Freezers
Fridge freezer controls
TURN THE FRIG. TEMP CONTROL TO COLDER THIS WILL OPEN THE FREEZER FLAP MORE AND LET MORE AIR IN FRIG.ALSO THE TEMP CONTROL COULD BE BAD,TURN ALL THE WAY OFF AN TURN ON SLOW AND LISTEN FOR A CLICK IF NO CLICK THE CONTROL IS BAD,THANKS-MIKE
May 25, 2008 | Freezers
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
FRIDGE FREEZER
What freezer not above.
Thanks J
Jan 03, 2008 | Freezers
Freezers Logo
2,569 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
