My samsung smart wash b1245S 6kg washes but won't spin, it displays an EU message on digital display, what is wrong ???
  • 1 more comment
  • MrCJ May 24, 2008
    my samsung smart wash b1245S washes and the drum goes round until 8 mins left on the program. error code SE is displayed. Machine will not drain or spin. Please help
  • janik_gosia Jan 12, 2009
    same problem with SE message
    can anyone help please
    same problem about SE error
    what does it mean,
    can anyone help?
Its your drain pump
must be a common problem on this machine. i have had to change the pump 4 times now in the 4 years i have had it.
they are about £8 off ebay including the postage
Posted on Jul 28, 2009
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
Samsung Washing Machine won't start
Your program controller unit is working but it must be ensured that there is output on every cycle to the desired output controls. So the inlet valve must work and the motor must run when the water level is triggered by the level controller. So use a meter to check before we can suspect the controller.
Nov 11, 2011 | Samsung Washing Machines
Hi, we have a Beko 6kg AA WMA652S and its not spinning. It won't spin during wash or at the end. Any idea what's wrong?
the problem might be the panel or it might be the washer pump that brings water out after wash
Jul 07, 2011 | Washing Machines
I have a samsung smart wash B1245S 6kg . when i set it on for a quick 30 min wash it will fill with water for about 10 mins . Then it will cut out and 4E will flash up on the digital display
Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
Dec 17, 2010 | Samsung Washing Machines
Samsung washing machine b1245s makes a grinding noise but wont spin...any ideas why and how to fix the problem?
i would grab a towel and check the pump for grit
and things that dont belong
may not be the actual problem but thats whered id start
have a great day
Oct 09, 2009 | Samsung B1245 Front Load Washer
I have a samsung B1245S washing machine error 53
5E - WATER DRAIN ERROR
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 02, 2009 | Washing Machines
Samsung b1245s washing machine
The error code HE2= water heater error (The heater element did not getting hot)
Unplug the machine to reset this error.
Try different cycle let see you still getting the same error.
May 07, 2008 | Samsung WF337AA Front Load Washer
Samsung smart wash b1245s doesn t work
motor brushes are worn and nead to be replaced easy job if you turn washer on to its side remove the 2 screws at the bottom and take off the plastic panel you can see the motor and the brushes are red plastic bits remove them and replace with new ones that should sort out the problem and cost about £25.00 to do .
Oct 13, 2007 | Washing Machines
Washing Machines Logo
383 people viewed this question
Top Washing Machines Experts
