Question about Frigidaire FRS-26DR7D Side by Side Refrigerator
Ice dispenser My ice dispenser is stuck in the crush mode. How do I get it back to regular ice cubes?
  • 1 more comment
  • Anonymous Aug 25, 2008
    how do i replace solenoid for crush/cube?
  • mleff Sep 25, 2008
    I can't believe it, after a year of no cubed ice through the door it's working again!! And all I had to do was press down on the little bar in the open square behind the ice bucket!
    Saved me over $100 for a service call, and $40 - $50 if I had tried to replace the solenoid myself!
    Hooray for FixYa!!!! Thanks!!!!!!
  • tkmsmith96 Mar 09, 2009
    I had the same problem, my ice kept coming out crushed. I pulled down the white bar in the square hole and pushed the metal bar above it and now my ice comes out cubed. Thank you guys so much!!!!!!
WOW YOU ARE GOOD IT SAVED ME $250.00 to have Sears come down and do the same thing...
Posted on Sep 15, 2008
  • 3 Answers
My freezer did the same thing after we had removed the ice making unit to emoty the ice. In our situation, the bar had not been reinserted into the proper slot and therefore could not toggle between the two choices. Be sure the long metal piece is IN the little box on the back wall of the freezer and you will be enjoying your ice maker again, I hope!
Posted on Sep 09, 2008
    Guru:
  • 93 Answers
The solenoid that controls the blades on the ice bucket is either froze up or defective. Remove the ice bucket and use a hair dryer on the back wall of the freezer where the bar on the ice bucket would go into the back wall. That plastic square in that hole should line up with the hole. Not be up inside the hole. Use the hair dryer on the back wall just above the hole with the plastic square inside it. The solenoid behind that wall is what controls the cubed and crushed ice. If that doesn't fix your problem replace the solenoid, Part Number 5304404333.
Let me Know how you Make out with your repair.
Thank you,
Bill
Posted on May 16, 2008
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: ICE Maker stuck in dispensing crushed Ice
That means that the evaporator fan system that releases the the ice cubes is not working.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
Posted on Nov 29, 2008
SOURCE: Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Posted on Mar 13, 2009
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
My Maytag Fridge Ice Dispenser stuck on crushed ice, so no whole cubes can dispense. What can I do?
If you look at the bottom out side area of the ice cube bucket/auger assembly, you will see a metal rod going front to back. That is the shift rod for cubes/crushed ice. Make sure it is free. Then look at the back of the refrigerator where the end of that rod goes into a square hole. There is a magnetic solenoid in that hole that shifts the rod for selection. The solenoid coil is either bad, unplugged, or for some reason stuck and not shifting that rod. That's where the problems is located.
Apr 12, 2015 | Maytag Refrigerators
Ice dispenser
sounds like u may need to replace the switch
Apr 03, 2014 | Frigidaire Refrigerators
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice instead of cube ice
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
Aug 17, 2009 | Refrigerators
Ice maker will only dispense crushed ice
You may have a broken solenoid inside the motor assembly.  The solenoid controls the arm for cubed or crushed ice.  The only way to tell is remove the ice dispenser motor assembly and look at the solenoid.  If the solenoid is broken, replace it and everything should be ok.
Aug 18, 2008 | LG LSC26905TT Side by Side Refrigerator
Frigidaire FRS-26DR7D Side by Side Refrigerator Logo
351 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
