Question about Rowenta DG-980 Iron
Does not steam. No pressure being built up.
I believe that it is not sealing tight around the water inlet screw. If I jiggle it then the pressure will sometimes build up. Can I purchase a new sealing knob, and if so where?
  • Roland Wong
    Roland Wong May 11, 2010
    Hi, Please make sure the unit is cool and unplugged. Remove the water inlet screw (use a quarter-coin) and inspect the inside neoprene seal (man-made black rubber) & the threads for cross-threaded damage). Drain ALL the water out of the unit by bringing the base unit to the kitchen sink. Reinstall the water inlet screw & seal and tighten 1/4 turn once the seal contacts the brass threads inside. Put the unit all back together less water in the reservoir. Turn the unit on and there should be a sizzling sound once the boiler comes up to temperature and boils residual water in the system into steam inside. There should be enough pressure to produce a single burst of steam...
    Scholar:
  • 70 Answers
I do not know if you did clarification request prior to ordering the new part.
Since I am in California, I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Posted on Jul 11, 2008
Leaky steam iron
First of all make sure it is air tight! If it has a crack or a break in the seal its probably not going to do you any good anymore. Try washing it and rinsing with vinegar to remove any material that may be stuck in there or get rid of mineral buildup from steam and water over time.
Apr 23, 2015 | Rowenta Power Duo Iron
Euro-Pro X
Check the hose for something clogging it. It will be past the flattened area (by that I mean further from the steam cleaner). It sounds like something got stuck in the hose, and as the steam cleaner kept sucking on the hose, it caused the hose to flatten.
Sep 08, 2007 | Euro-Pro Steam Generator EP8001 Iron
Steam comes out of the place where you put the water in
check the holes in the hot plate are not blocked with lime scale...sounds like you have a back pressure problem
Dec 29, 2012 | Rowenta DG5030 Iron
I have a hinari steam generator iron and the steam has stopped coming through the iron and now coming through the base that the iron stands on!can anyone help please
Check the water reservoir of the steam generator and look for some hairline cracks. Also a clogged tubing will likely to go back water on reservoir inlet water pouring. Once you found the cracks, seal it with epoxy just enough to fill the cracks.
Thanks for asking.
Jul 13, 2011 | Rowenta Steam Generator DG050 Iron
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
I have a Rowenta steam iron and it has been leaking, not steaming properly. also, I have been using tap water. How can I clean it? Can I use the products designed for dishwashers, like "Glisten" to rid...
the loss of steam is from usually from a barrier or o-ring or some sort of insulating material it has to be sealed because if it is not the the steam will not build up the pressure required for adequate cleaning power, try to seal up where the water is coming from, and yes you should be able to use something to get rid of the build up just make sure you rinse it all out so it wont mess anythng up and tap water is fine you will just get that build up from it cause of the chlorine and other products in tap hope this was helpful:)
Nov 16, 2009 | Rowenta Commercial Garment Steamer - White
Steam Fast SP-660 Iron will not steam with distilled water.
Steamfast Brand SP-660 steam press
Mfg by Top Innovations
Phone 1-800-711-6617
Nov 10, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Parts
Call 800-711-6617 to get a new Hose Base for $3.00. I just ordered three of them and with shipping it was around $17.00. They didn't give me the part number.
Jul 05, 2008 | Steam Fast SF-450 Iron
Rowenta DG-980 Iron Logo
164 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
