Can my logitech 5550 speakers be used without a pc or a stereo amplifier, eg. a digital dvd player only.
Im looking for a subbofer... i would buy it....
ali +353 85 722 39 48
Thanks........
Posted on Jun 16, 2008
I have an apex ad-5131 dvd player i want to hoook up speakers to to but how? i dont understand the coaxil i matched all of them by color to color but it still doesn't work
The outputs on the dvd are line level and will need to be hooked up to an external amplifier or stereo receiver in order to make speaker work...all you do is hook the audio output right (red) and left(white) to the amplifier and then hook the speakers to the speaker outputs on the amplifier
Jan 20, 2011 | Apex Digital AD-5131 DVD Player
My pc is a media center pc and I have purchased the logitech X-530 speakers but can only hear out of 2 of them??
you need to go to your audio conotrol software and set up your sound card for digital output, and or connect with the digital cable, it appears you have either connected them with a stereo (2 channel) cable, Or have correctly connected, but not told your interface that you have a digital conneted speaker system. To find it in your computer, try Start --> Programs --> Accesories --> Entertainment --> Volume control, and click on advanced to access the speaker setup
Feb 08, 2010 | Samsung BD-P1600 Blu-ray Disc Player
The speakers wil not play on the background and the center.
If you connected to a 5.1 surround card and checked and they are connected ok you can hear all the speakers when you play music, movies that are in 5.1 format only. If you want to hear also all of them if you listen to stereo movies/music you must set the sound card to emulate multi channel. Also the player you use to listen music/wath movies must be set to 5.1 and must accept Dolby Digital/ DTS decoding if your sound card doesn't(eg. VLC media player-has integrated DD and DTS decoding and codecs for all tipes/formats).
Oct 13, 2009 | Logitech X-530 Computer Speakers
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
I have a sharp TV. Using the Pioneer DV 410 VK dvd player. Is there any way i can use a 5.1 speaker system with this ?
thourh coaxial or optical you can use a 5.1 amplified speaker check digital input compatible
Jul 17, 2009 | Pioneer DV410V DVD Player
I CAN NOT GET ALL 5 SPEAKERS TO WORK
I know this is not the answer that you want to hear, but: That television is not capable of delivering audio output to all 5 speakers - it is a stereo-only TV, which only delivers 2 channels.
Furthermore, that Coby DVD-937 only has Digital Audio outputs rather than inputs, which is very strange and complicates our problem immensely. You will get 5-channels with DVD or radio play, but getting 5 channels for TV is not possible without additional equipment.
The manual for the Coby mentions a "Digital Decoder Amplifier," which would work. You would connect a digital audio cable from the area marked "Coaxial" on the back of the Coby to a digital audio IN on the back of an external amplifier. You would connect the speakers to this amplifier, instead of directly to the back of the Coby. Then you would need a cable or satellite box with digital audio outs (fairly common nowadays) to another digital audio IN on the back of the amplifier. The cable or sat box you may have already, but you may need to purchase such a "Digital Decoder Amplifier" or other digital amplifier with appropriate speaker wires and 2 digital audio input slots (not to mention two digital audio cables). Fairly complex. Possibly expensive.
-Tha Mp3 Doctor
Feb 20, 2009 | Coby DVD-937 5.1 Channel DVD...
Amplifier problem
Here's the basic problem. The DVD player can get a 5.1 audio source from the DVD. That signal is then converted from Digital to Analog and split into 6 channels of information. Each channel has an audio out on the back of your player. You are only using the Front L and Front R outputs. Based on how I read your description, they seem to be sent from your DVD to your TV, and then from your TV to your receiver. The problem is that you are only listening to two of the six channel, so you are losing a lot of information. How this sounds to you depends, in part, on how the sound is mixed on the DVD (5.1 versus just stereo, for example).
Because you don't have 5.1 system to take all six outputs (analog "DVD Audio" connections), you shouldn't be using those outputs. You could use the digital out (optical or coax SP/DIF) to send all channels to a receiver that could do the splitting (D/A), but it sounds like you don't have the equipment for that.
You didn't provide the model for the LG DVD, but there should be connections for analog stereo. They would be labeled as Audio Out L / R, or something similar. The connections are stereo, but your player would use all 5.1 channels to play through those stereo channels. You could connect those directly to your receiver, or you can continue trying to have the TV as a step in between (not suggested unless you just like to watch DVDs without turning on the receiver).
May 12, 2008 | Audio Players & Recorders
How to connect my Logitech X-540 speaker system to my dvd player or tv
On the logitech speakers, connect all the colored cables to their coordinating colors on the back of the subwoofer EXCEPT the green one..you need the special Y connector that came with the speakers. (the red, white and green little one). Connect one end of the green cable to the subwoofer, connect the other end to the Y connector. Now you just need to correct the red and white cables from your tv or dvd player into those red and white cables and MWAH!!
Mar 01, 2008 | Logitech X-540 Computer Speakers
Can the cable ends be converted to fit a DVD?
You can certainly purchase a cable or an adaptor to connect the speakers to almost anything - this however is not the issue - z5300 computer speakers have an impedance of 8 ohms, whereas most home theatre systems will be set up to use speakers with an impedance of 4 Ohms or 6 ohms or 8 ohms - using the wrong type in the wrong configuration is very likely to result in damage. Also the speakers contain their own amplifier, and are designed to accept an input that has not been amplified to speaker levels before - most tv/dvd audio output will be amplified, depending on the model, so will almost certainly destroy your speakers unless you have a low amplification output on your tv/dvd. If you post back with the make and model of your tv and dvd player, hopefully i can find the necessary info to describe how you could make the connection if it is possible. Logitech says; "Logitech speakers are powered speakers and are designed to be used with a home computer. However, it is still possible to connect your speakers to many other devices. You can connect any Logitech speaker to any device that has a pre-amp mini-headphone jack. Home amplifiers will normally contain a standard ¼" headphone jack. You'll need to purchase a ¼" to 1/8th" adapter to connect your Logitech speakers to a home amplifier. Note: Under no circumstances should you connect your Logitech speaker system to an amplified output such as the rear outputs of a home amplifier. Doing so may cause damage to your Logitech speakers as well as your home amplifier." Hope this helps - please post back with details :)
Apr 19, 2007 | Logitech Z-5300 Computer Speakers
Connecting dvd player to logitech x-530
Well, if you have a DVD-ROM, all you need is a video card with a s-video out to connect to your TV and then you could put your DVD player in your room and play your DVD's from your PC. Another way to do it (without having to buy anything) is to connect the sound of your DVD player to a stereo receiver and then plug the sub into the headphone jacks and the speakers to the sub.
Mar 19, 2007 | Logitech X-530 5.1 Channel Speaker System...
98 people viewed this question
 Grubhead
Grubhead
