Question about KitchenAid KGRA806PSS Gas Kitchen Range
Fuse HI, Did you find the fuse on your oven? THanks
    Habit-Forming:
  • 76 Answers
No fuse thermal cut out. small themal disk on back of range. should be closed. if open will need thermal disk and possible vent kit
Posted on Nov 28, 2008
Hi there. I need to change the fuses on my oven,
hello,
Instruction below.
  • Unplug your oven. Insert the size 15 Security Torx bit into your multi-bit screwdriver and remove the screws from the back panel. Take off the back panel.
  • 2 Locate the fuse. It should be near where the electrical cord comes into the oven. The fuse is a small white bar with metal caps on either end. Carefully remove the fuse. Avoid touching the transformer or other parts inside the oven.
  • 3 Purchase a new fuse. Most whirlpool ovens use an 18 amp ceramic fuse. Consult your owner's manual to find out what kind of fuse is used, or take the old fuse into the store to find the exact match.
  • 4 Replace the fuse. Put the cover back on and see if your oven works. If it does, replace the screws. If it does not, try a different fuse. If the oven still does not turn on, you may have to have it replaced of professionally repaired.
  • thanks and thanks for visiting.
    Oct 09, 2010 | Ovens
    Microwave not heating,stopped suddenly.Everything else works.
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    dhj
    Jun 01, 2010 | Amana AMV1162 Microwave Oven
    Power to back of oven going in and out of the oven but nothing happening not even the clock is coming on. please help.
    Hi
    Thanks for using FixYa. When microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Feb 13, 2010 | Belling Microwave Ovens
    Display reads code F03 on Whirlpool oven. Can I
    Hi
    Thanks for using FixYa. F3 error means Open oven temperature sensor or thermal fuse. You’ll need to replace oven temperature sensor or thermal fuse to resolve the issue.
    Thanks
    Rylee
    Jan 15, 2010 | Whirlpool RBD305PD Electric Double Oven
    Ge microwave blows fuses, replaced fuse after hiltonjug's excellent advice and the next day it went through another one, doesn't sound good. Thanks, Jeff
    have you checked/replaced the : HI-Voltage capacitor,the HI-Voltage Diode, and checked the unit for current draw while its in operation?these are three main components of fuse failure
    Sep 06, 2009 | GE JVM1330BW/WW Microwave Oven
    Oven tripped fuse and will not turn on
    Hi!
    If the oven is not working, you need to check the fuse on the main PCB - If the fuse is good check for continuity between the fuse and L3 (drive motor terminal) - If this circuit is open the PCB is bad and must be replaced. When re-assembling please be sure all the wiring is correct.
    For your reference, you can check the following link---
    Dacor Epicure Electric Oven Technical Manual
    Please do accept this solution and revert for further assistance.
    Thanks
    Rylee
    May 31, 2009 | Dacor ECD230 Epicure Electric Double Oven
    Microwave went dead
    Hi
    If your microwave oven doesn't seem to work at all, check these: Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
    Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
    Please do rate the solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    Apr 26, 2009 | Whirlpool MH7140XF Microwave Oven
    Microwave has no power
    Hi
    Thanks
    Rylee
    Jan 15, 2009 | Whirlpool MH7135XE Microwave Oven
    Oven doesn't work.
    HI. thanks for your question. i would replace the 2. 30 amp fuses in the stove. try that. if not repaired. check the timer. it must be set to MANUAL, for the oven to work, check that.thanks the appliance doc. please rate my answer. thanks
    Oct 08, 2008 | Ovens
    KitchenAid KGRA806PSS Gas Kitchen Range Logo
    230 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Dan Webster
    Dan Webster
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
