Question about Olympus P-440 Thermal Photo Printer
Olympus P-440 Thermal Photo Will nOt print
Have PC card&SD Flash card card will not register&Ican not get disk inalled on window Driver will not work
  • elco32 Apr 17, 2008
    NO Solution I already Have Premium Assistance Plan Printer do notwork SD card &PCwill not register in Printer Can not insalled Disk
3 Suggested Answers
SOURCE: Can't find drivers for Windows 7 for the Olympus P-440 Printer
Talked to the dudes at Olympus...won't work on a 64bit. Im in the same boat :(
Posted on Jun 10, 2010
firesnake09
  • 2923 Answers
SOURCE: Olympus P-440 doesn't work with Snow Leopard. What
The first thing that you need to do is to verify if your Olympus P-440 is if it's supported by Mac OSX 10.6.x (Snow Leopard). If yes, make sure that you've installed the correct driver for Snow Leopard.
You may check the link below:
http://driverscollection.com/?file_cid=41942227668e7c7e22782bc2081
This link contains a driver for Mac OSX. I assume that this driver will work with all OSX (starting from Tiger to Snow Leopard). If this driver will not help, you may need to contact the manufacturer, and verify the system requirements of your printer.
Thank you and good luck!
Posted on Jul 22, 2010
Olympus P 400 driver mac 10.84
Olympus has not supported that printer on the Mac in 10+ years. Also checking the Apple printer driver support page I do not see ANY Olympus printers currently supported by Apple: OS Printer and scanner software available for download
I would suggest replacing that printer with a current model photo printer (also Dye-Sub) from Canon. The Canon Selphy Dye-Sub photo printers produce flawless professional glossy prints: Compact Photo Printers
Dec 05, 2013 | Olympus P 400 Thermal Printer
Olympus P440
well..good morning...what 'card' are you referring to on this, please?
Mar 29, 2008 | Olympus P-440 Thermal Photo Printer
The colors print misaligned, the blue and yellow print and then the rest print just off to the side
Had the same problem. The colours were mis aligned, or out of register. Tried everything, but nothing worked. Was going to toss it out, then tried changing the paper size in the print setup window of Photoshop to A4. Just make sure whatever Photo program you are printing from to choose A4 as the paper size. Printer worked fine after I did this.
Jan 26, 2011 | Olympus P 400 Thermal Printer
Jul 22, 2010 | Olympus P-440 Thermal Photo Printer
May 17, 2010 | Olympus P-440 Thermal Photo Printer
White lines in on my prints
your printer catridge has been faulty.so pls replace it.
Sep 07, 2009 | Olympus P-440 Thermal Photo Printer
Olympus P440 Dose not work on Vista
The driver for the P-440 printer will work in Windows Vista. To install it you will need to run it in Windows compatibility mode XP service pack 2. Download the P-440 driver to your desktop from the olympusamerica.com website. Open the zip file, right click the mouse on the setup.exe file then left click on Properties. There will be a compatibility tab there. Select XP Service pack 2 and then click Ok. Connect the printer and as it goes through the found new hardware wizard direct to the folder location on your desktop for the files it needs to load the device driver.
Nov 17, 2008 | Olympus P-440 Thermal Photo Printer
Olymus P-440 dont work with Vista
I finally had time to sit and get my Olympus P-400 to work on Vista. I am using Vista 32 bit Service Pack 1.
Good thing I did this as I almost sold it!
Here's what you do: I created a new file folder on the Desktop to make this a little easier.
Using the original disk browse to the Acroread file folder, than to your specific language file and Copy the file ar405eng.exe to your Desktop in your new folder. The "eng" is for English.
Right mouse click the ar405eng.exe and select Properties.
Than select the Compatibility Tab.
Select Compatibility Mode and select "Windows 98/ME"
Also select "Run this program as an Administrator"
When I ran it it coped the .inf and DLL files to their own file. Do a search and locate files starting with "Olympus".
Got to Control Panel
Go to Printers
Click Add Printer
Choose Local Printer
Choose Have a Disk
Browse to the location where the .inf and DLL files are located when you did the search.
This installed the correct driver and I was able to print using Photoshop without error.
Hope this helps!!!!!!!!!!!!!!
Apr 06, 2008 | Olympus P-440 Thermal Photo Printer
Olympus P-440 Thermal Photo Printer Logo
Top Olympus Office Equipment & Supplies Experts
James Cagle
James Cagle
John Tripp
John Tripp
Are you an Olympus Office Equipment and Supply Expert? Answer questions, earn points and help others
