FixYa.com
Tags:
Emerson MW8107WA 1000 Watts Microwave Oven
No Power
posted by rmcbeast44 on Apr 14, 2008
When I plug it the digital is not showing or no power at the mocrowave.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 01, 2008
FixYa! (100)
IrishDruid
Rank:Guru Guru
Rating: 87%, 704 votes
Try plugging in another device into that wall socket and see if works or not. If it does, it could indicate a problem withe the power supply unit your microwave, which will have to be serviced by a qualified technician.
If, however, the other device does not work as well, that could indicate that the wall socket is faulty. You will need an electrician.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Comment by IrishDruid, posted on May 03, 2008
Just wanted to inquire if your issue is resolved, or if there is anything further I can do to assist you…
If you find that the solution/answer I provided led you to, or resulted in a fix, please take a moment to close the ticket with a FixYa! rating under my solution. I would be very grateful for your show of appreciation.
Cheers!
IrishDruid
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Microwave Ovens problems?
Microwave Ovens
it says its locked
it says its locked Answer This...
Microwave Ovens
Where is the light bulb
Where is the light bulb on... Answer This...
emerson 1000 watts
i have power, but button will... Answer This...
Comes on but........
The microwave and light comes... Answer This...
water has penetrated inside the...
when I was cleaning the door, I... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
