Question about Samsung RS2556 Side by Side Refrigerator
Cricket noise from samsung side by side refrigerator
My side by side refrigerator makes a noise that sounds like crickets only about 40 percent of the time. It may be defrost stage or something. Is there anything I could try before calling a repair person. The fridge is only 3 years old.
  • Anonymous Feb 01, 2009
    I have a brand new GE profile refridgerator lower drawer freezer that makes a squealing or cricket chirping type noise. They replaced the rear fan motor but the noise is still there. It occurs intermittenley but can be heard anywhere in the house. Technician is clueless, can you help me solve my problem? model # PFRS5NBXBSS
    T.
  • 42 Answers
SOURCE: Samsung RSE8KPUS noise
I have worked on refrigerators for 30 years but never worked on a Samsung. This is a WILD and I do mean WILD guess at what the noise may be. Don't use this information to attempt a repair but just to track where noise may be coming from.
There is a motorized damper door that opens and closes between the freezer section and the refrigerator section. My guess is that that damper assembly is what is making this noise. I can not tell you why it may be making this noise except that if is making the noise it probably is going bad. Remember this is just a guess and you will need to locate the damper assembly in order to try to pinpoint the origin of the sound. Your recording was wonderful and I wish more people in my everyday job would use their heads like you. I hope this sheds some light on the problem. Remember I am just guessing, don't spend money till you are able to verify cause.
Seems there would be a 1 year warranty on the frig.
supertechks
Posted on Nov 22, 2007
SOURCE: Cooltech super xflow not circulating
hi
there is problem with x flow motor which is located inside the ref temp. assy. in frige section.this problem dosen't affect the cooling of fridge.this problem can resolved by replacing the x flow motor
yours
sandesh
Posted on Jun 01, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
landsend
  • 1066 Answers
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle.  Call a tech repairman
Posted on Mar 27, 2009
SOURCE: noise (more detail)
I think I answered this in an earlier post.
The noise is the fan banging against the motor housing. It's not a defective motor, it's a poorly designed motor.
The solution is to shim the motor mount so it is slightly out of level which will keep the fan from bouncing off the motor housing.
The reason Samsung won't service is they don't understand the problem. I've seen this a half-dozen times.
Trust me -- SHIM THE MOTOR MOUNT!
Posted on May 27, 2009
Do I have a 20 pound cricket behind the refrigerator??
That's the compressor. Check the compressor mounts to see if they are cracked, loose, or have hardened or broken rubber bushings. Also check to see if the compressor housing is improperly touching something that transmits its vibration and acts like a sounding board. Sometimes there is a problem with freezer icing in high humidity conditions, leading to ice buildup on the refrigerant tubing at the compressor (excessive running) - this makes the tubing insulation rigid and things get really noisy. The fix is to shut everything down, let it defrost, and clean out the defroster drain tube.
If you can't find anything like that, you may have something going out in the compressor. If possible, make an audio recording and play it for a service technician at an appliance shop - he may be able to identify exactly what the problem is.
May 08, 2014 | Refrigerators
Turn on predictive text cricket samsung transfix
On the SCH-R470C Samsung phone from CRICKET, you have to brig up the keyboard, (as if you were Texting someone ) and there is a Key on the bottom left side of the Keyboard that looks like a small "Gear". That brings up the "Settings" menu - uncheck the box that says "Predictive Text". Whoever invented that incredibly annoying feature should be severely beaten with both vowels & consonants...
Aug 02, 2012 | Samsung Transfix R730 R 730 Android...
My smeg fridge is making a constant cricket sound noise constantly
first check for a cricket
if no cricket is found, it's likely one of your 2 fans. one will be down by the compressor and the other is inside the freezer compartment.
May 22, 2012 | Refrigerators
Chirping cricket sound
oopppsss.. time for replacement
Jun 19, 2017 | Western Digital 500GB My Passport...
This is the 2nd Samsung Cricket wireless that I have gotten and AGAIN my sounds are gone. It says SILENT MODE ACTIVATED...what's going on with this phone? It's frustrating on emergency calls and it doesnt...
My name is Marty and I work on behalf of Cricket Wireless. We recommend bringing your phone into a cricket corporate store to have it looked at by one of our technicians. They'll be able to help find the exact cause of the problem. Hope this help!
Mar 16, 2011 | Samsung E950 Mobile Phone
After 14 months and 3 refrigerators, I'm giving up. The RF265 and RF263 series refrigerators make loud popping sounds. I've been through two RF265s and one RF263, and they all make the same noise. The...
I have had what sounds like the same problem for over a year with my Samsung RF263 refrig. It makes very loud popping noises like expansion noises when heat hits your house siding or a railroad track. The noises are loud enough that they actually startle people, and our cat. I had a repair man in last May 2013 but no luck.
I finally did a lot of listening, testing, etc. and found the problem. I noticed it would occur whenever the compressor came on. I thought it might be ice build up, so I took the cover plate off over the evaporator in the back of the refrig compartment. There was no ice build up. I then left the cover off and wiring attached and no noise after a day. After a few other trials I added some more weather stripping to increase the distance between the evaporator coils and the cover plate and that help quite a bit but not totally. I still get a pop now and then. Another problem I noticed with this partial solution is that it causes the shelving to not be aligned. A 'V' gap forms between the shelves and they droop a little. I'm still trying to figure out how to fix this but haven't had any good ideas yet.
This is a very annoying problem and a design flaw in my opinion. Whether Samsung has a solution for it I don't know but I plan on checking before my warranty runs out.
Dan
Jan 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung refrig fan noise-sounds like cricket.
sounds like the bearing is starting to get tight in the fan motor. i would replace the fan motor.
Oct 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Ge compressor makes cricket sounds while running
yes from what you've said it is the bearings if there not bad then there on there way. good luck
Mar 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I don't have the cd key for EA Sports Cricket 07 for Windows
u should ask help from a computer expert im 99 percent sure it will work
Mar 21, 2009 | EA Sports Cricket 07 for Windows
Samsung RS2556 Side by Side Refrigerator Logo
109 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
