SOURCE: Nokia 3230 start-up failed
have you tried reformatting it??
try this
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to
#*7370). It is useful in some cases, for example when the phone cannot
reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Hi, Format the Mobile set, using 4 Keys combination : Press(1) *, (2)Dial Key, (3) 3 & hold it & press (4) power on switch.] bye [email protected]
SOURCE: Help please! My nokia 3230 failed to start up.
Try this, it might work for you. First remove any extra memory card and sim card inside your phone. After doing that, turn on your phone without those things. If there is message "Please insert sim card" then your good to go. Put your sim card back to your phone and then turn it on again. If it is successfully start then next thing to do is to insert the memory card back to your phone and then start up your phone again. But if in this stage your phone failed to start, then the memory card it causing the problem.
If all fails, then you need to format or hard reset your phone. Hold the * + 3 + green call key and then start up your phone while holding those buttons until you see a screen that shows formatting. Make sure you have enough battery power to do this procedure. You can plug the phone charger to make sure that everything will be okay.
Please leave comments for further instructions. Thanks..
i have problem regarding phone memory there is nothing but it shows about 1600kb of its memory is full plz tell me what to do plz send answer on my email as soon as possible
hi..., i have the same problem.
when i start my nokia 3230 i t only shows the brand name NOKIA three times and turns off.
what should i do ?
i also want to save my contact no.s
please help me with this.
-prashant
my nokia phone starts up showing just the brand name and then switches off. it does this three times or 4 times. all my contacts, calendar alarms etc r lost n want to retrieve them. please help me
send me your solution to [email protected]
my nokia 3230 mobile is troubling while starting the mobile
