Question about GPX D1816 DVD Player
Hooking up DVR to TV
I have 3 sets of red, white and yellow on the back of my TV.
I dont know which ones the cables go into even though they are color coded. one that says Video and it is yellow
the white and red say L and R
And they are all lined up on top of each other side by side
Does this make sense can you help
These are an alternative connection to scart leads, with 2/3 round connectors instead of the squarish black one. on a dvd player, video etc you sometimes have the option of using these instead of a scart plug (though not both toigether) and are also usefull to connect up video games machines such as the wii and xbox. normally the connectors are colour coded so red to red, yellow to yellow, etc, and would normally be switched to by the av button on your tv remote
Posted on Aug 10, 2008
  • 3 Answers
Harleynut, you should see AV1, AV2 on your TV where the cables go. Choose one or the other. Then, Place the yellow in Video and the White in Audio L and the Red in the audio slot next to it.
Posted on May 09, 2008
Dont realy have a problem just ned to know how to set up to my tv
There is an output for this device colored red, white and yellow. So the red and white is for the audio and the yellow is for video. Use an RCA cable with the same color. plug it at the back of your dvd matching the colors of the output jack and plug the end of the cables to the input part of your tv. So the red and white should be plug in to the "AUDIO IN" and the yellow should be plug in to the "VIDEO IN" on your tv, Set the tv to video and press play on the dvd.
Sep 09, 2010 | Haier Portable DVD Player PDVD7
We just purchased a toshiba DVD video recorder DR430KU and can not get it to work with our Samsung bit screen tv .. we have satilite tv
I had a similar problem. After disconnecting my devices and rehooking them again. Was that you may need to reset the DVR to channel 3 or 4. Or go to settings and see if you see a a menu that reads "Reset to Factory Setings." Try clicking that and see if you can record from you DVR after you do it. It may be that your DVR was on the wrong channel of the DVR. I found this true with mine, it was set to channel 3. How it jumped to that channel is a mystery. Make suire your connections are correct in the back of the T.V. Red to Red, yellow to yellow, or white to white and "In to out." On the back of my HDTV it was so different. The cables from my DVR were R, Y, W. But on the back of my T.V. it was Green to Yellow, Red to Red Stereo, and White to White Mono. My instructions did not match what I had on my T.V. that is why it is very confusing. And 2. the instructions are too small for me to read. I called Customer Support for Toshiba T.V.'s. They told me to call Customer Support for Toshiba DVR. Which I did and they were also not able to help me. Then they told me to call Toshiba Customer Service for Toshiba DVR. I went back and forth. I did mention that before or the old way used to be that when you had an old VCR, you always had to put or switch the channel to Channel to 3 or 4. But they did not know what I was talking about.
I finally reset the DVR to factory settings myself. I am almost 100 per cent sure that it will work now. Good luck, and I sure hope this helps.
May 02, 2010 | Toshiba Televison & Video
I need to know where to plug in my connectors for my cable box. I have two red ones and one blue one I can't find the right holes to plug them in. I have a green one and white one fixed so I have a black...
This would be 5 pins, red-white is for audio and rest of 3 pins red-green-blue for video signal, it calls component video.
Find out red-green-blue jacks at back of TV that would be label as Y, Yr, Yb
Plug each pin in same color to get color picture.
Jan 08, 2010 | Proscan 32LA30Q Television
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Im a girl, & i need help hooking up my ps3 to my flatscreen
ok it should all go into your tv ok? and there should be a row of yellow white red or any order (ON THE FRONT). you should look on the back of your tv or side for alot rows of inputs and each row should be for an different input on your tv like input 1 2 3 4 5 6? you follow? so just match the colors up on the back or side of your tv or front do not hook it up to your cable box..........Ahh i see the cable box is using the yellow one well maybe unplug that while your playing or there would prolly be other (RED WHITE YELLOW) on the back of your tv like i said or on the side
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
Hook it up to the tv
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
May 10, 2009 | Televison & Video
Adding a dvd player to my dvr and older tv
leave coaxcil cable on dvr ;unplug the colored wires from the dvr output and plug them into the output of the recorder;plug a second set of colored wires into output of dvr and into input of recorder;be sure to set recorder input to proper setting on recorder (input one or two) now you should be able to record what your dvr plays or just use it as a dvd player ; you will need to have all three on to watch tv though.
Mar 01, 2009 | Cyberhome DVD Recorder - DVR1600
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
No sound - no video on TV
if you're hooking your VCR via analog video input of your TV then check that the yellow colored video wire goes to yout TV video input, will also be colored yellow inside the terminal. The white and red color inputs are for audio. Likewise the output of your VCD will have the same colord code Yellow for video, red/white for audio (stereo). After setting this up, select your TV function to video in, be sure to check your video input channel as well if you're having more than one video input. Video 1 or 2 or 3. Make sure your VCR is powered up when you start to setup your TV function select.
if you're hooking your VCR to your TV via RF signal (over your TV tuner) You need to scan the right frequency to get it tuned to your TV channel. Cabling willbe via RF antenna input of your TV and RF antenna out of your VCR.
Mar 17, 2008 | Televison & Video
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
GPX D1816 DVD Player Logo
162 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
