Question about Frigidaire FGF376 Gas Kitchen Range
Excessive preheat time, occasional gas smell.
My Frigidaire FGF376 Range has recently started taking an average of 40+ minutes to preheat to 415 degrees, where it used to only take about 15-20. Occasionlly we get a whiff of gas as well, this range is about two or three years old. thanks
  • reginaprez Oct 06, 2008
    I have the same problem. The oven takes forever to preheat to even 350 degrees (30 plus minutes) and also have a smell of gas. My oven is also about 4 years old.
  • 125 Answers
SOURCE: frigidaire gas range
You could have a gas leak on one of the connections or a leaking safety valve. Mix some dishsoap, (dawn, etc) with water, 50/50. Soak the connections and fittings on the incoming line to the range. If You get bubbles you found the leak. Next find the orfice for the bake burner, take out the drawer and you should see the tube in the center. It will have an opening in the bottom where the orfice goes in. The orfice is brass, spray some soap bubbles on the brass orfice and see if it bubbles, if it does you need a new safety valve. Still no bubbles open the oven and look on the back wall of the cavity for the broil orfice ( if it has a broil burner). Hope that helps
Posted on Jan 10, 2008
szwaan
  • 209 Answers
SOURCE: frigidaire ples389ece range
http://www.frigidaire.com/support/ResultsPage.asp?strModel=ples389ece&User=&Search=Search
That website has a manual for your Range and it should explain the F20 code.
I'm gonan look through the manual and check out what F20 means so ill be back in a bit.
Posted on Jan 20, 2008
SOURCE: bybass auto shutoff (frigidaire gas range ES340)
Look on page 10 of the use and care manual under "To Set Control for Continuous Bake or 12 Hour Energy Saving" Page 10 in my manual.
Posted on Sep 09, 2008
SOURCE: It take a long time for my gas range to pre-heat
the oven flame seems to be to low, that flame most be at least 2 inches long. not counting the sides of flame from one side of the burner to the other, but from where the flame begins at the metal of the burner.
Posted on Dec 11, 2008
  • 9 Answers
SOURCE: Frigidaire Gas Range Oven not getting hot - FGF376CEFP
DEAR CORDLESS TRY CHANGEING THE GLOW IGNITER THE GLOW IGNITER GOES BAD AFTER A FEW YEARS AND YOU HAVE TO CHANGE THEM YOUR BURNER SHOULD LIGHT IN 30 TO 60 SECONDS IF YOUR GLOW IGNITER IS NOT DRAWING ENOUGH AMPS YOU WILL SMELL GAS BUT NOT IGNIGHT THANKS GEORGE
Posted on Apr 11, 2009
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
When i turn on my oven it smells like gas
Shut oven off & call the gas company. This is nothing to mess with. Seriously.
Nov 05, 2017 | Frigidaire FGF378AC Gas Kitchen Range
I turn on oven and can smell gas for a minute,then hear it ignite
I tapped on the valve a couple of times and it seems to work fine now.
Dec 09, 2009 | Kitchen Ranges
Occasional gas smell
If you have a burner lit and gas build up, strong smell etc., my advice would be to stop using the oven immediately! You no way gas should come out, build up, to the point you smell it, Especially while a burner is lit. Dangerous condition.
Jun 21, 2009 | Viking VGIC305-4B Gas Kitchen Range
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
Frigidaire lp gas oven
YOUR OVEN GLOW IG NITER IS SUPPOSE TO STAY ON THAT'S NORMAL. WHAT YOU NEED TO DO IS CHANGE THE ORIFICES ON YOUR OVEN VALVE BECAUSE YOUR USING LP GAS MOST OVENS COME NEW SET UP FOR NATURAL GAS ALL OF THEM EVEN YOUR COOKTOP
ALSO
May 22, 2008 | Frigidaire FGF376 Gas Kitchen Range
Oven takes up to 25 min. to preheat
I would suggest looking at how long before the bake burner ignites. If taking longer than 5 minutes before it ignites, then you are looking at a possible bad ignitor. The ignitors just don't last more than 5 yrs with regular use.
Jan 06, 2008 | Tappan TGF320 Gas Kitchen Range
Oct 29, 2007 | Frigidaire FGF376 Gas Kitchen Range
Frigidaire FGF376 Gas Kitchen Range Logo
56 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
