Question about GN Netcom GN 9120 Professional Headset
No Dial Tone
When I pick up the headset it lifts the receiver off of the phone itself, but there is not a dial tone. There is a dial in the back of the base, and if you turn it, then there is a dial tone. I checked all of the hook-ups, they are all properly attached, and I know that it is fully charged... What do I do?
  • troyster Jul 09, 2008
    I have the same issue with the exact same model - battery is fully charged and it lifts the handset but no dial tone
2 Suggested Answers
SOURCE: Not getting a dial tone
try turning the nob on the back of the base.
Posted on Mar 07, 2011
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
Phone does not dial out any numbers.
Check the side of the phone. Look for TONE / PULSE selection.
MOVE it back and forth and leave it to TONE.
Test it again,
Jan 18, 2014 | Northwest Bell Nw Bell Wht Corded - Big...
Driverts calls
Hi, You can use this instruction to activate and de-activate Call divert .Works on all phone
Turning Call Divert On
by Touch Tone phone
Step 1 Lift the receiver and listen for the dial tone.
Step 2 Press the Divert On button if using an Optus OneTouch phone, or dial *78 from any other touch tone phone.
Step 3 Listen for three beeps followed by a continuous tone.
Step 4 Dial the telephone number to which the calls are to be diverted.
Step 5 Listen for two short beeps, confirming the diversion.
Step 6 Replace the receiver
Turning Call Divert Off
By Touch Tone phone
Step1 Lift the receiver and listen for the dial tone
Step2 Press the Divert Off button if using an Optus OneTouch phone, or dial #78 from any other touch tone phone
Step3 Listen for two short beeps to confirm removal of the diversion
Step4 Replace the receiver.
Other Call Divert Options - Selective Calls
With selective call options, you can choose which numbers you wish to divert, accept or reject by adding these numbers to a list. You can list up to 30 numbers for each call option.
Turning On or Off Selective Call Options
Step2 Press the access code for the service you require. You will hear a prompt telling you the status of the service and how many telephone numbers you have on your list. To turn the service on/off press 3.
Access codes Dial
*63 for Selective Call Divert Dial
*68 for Selective Call Accept Dial
*60 for Selective Call Reject
Step3 For Selective Call Divert you will then hear the 'divert to' number that is currently entered. If this number is correct press 1. If it is incorrect, press 0, then re-enter the phone number you wish to have your calls diverted to. When turning this feature off dial 3 again.
Step 4 The feature is now on/off.
Step 5 Replace the receiver.
Note: You can divert calls to a local, national or mobile. However, you cannot divert calls to emergency, 0055, 1900, 008, 1800, 0050, 13, 1300 or international numbers.
Hope it helped.
Thanks for using fixya...
Jan 11, 2011 | Cell Phones
Everytime i hit the blue button on the desk set i don't hear a dial tone in my head piece
Two things to remember. If you're connected through the handset jack, the handset (receiver) needs to be lifted off the phone to get a dial tone. Secondly, if you're connected through the headset jack, you may need to adjust the configuration dial (round dial on left-hand side of base) to make it work when the headset button on phone is pushed.
Good luck from Headsets Direct!
Aug 24, 2010 | Plantronics Voyager 500A Deskphone Adapter...
Speed dial
1. lift the handset and listen for the dial tone. 2. press the store button 3. dial the number that you wish to store 4. press the store button a second time 5. press one of the numbers on the phone [0-9] and that will become the speed dial number. 6. make a record of the speed dial number and the name of the person it will call.
Then when you want the person on speed dial number 5, just pick up the receiver, get a dial tone and push 5. Thats it!
ps - kindly rate my answer as helpful. thanks
Feb 19, 2010 | Southwestern Bell Freedom Phone FM2552
No dial tone in Clarity C4230 setup
if you can get dial tone with another phone, look into manual for any instructions, usually a toll free number for help. ( BEST ) otherwise take phone back for exchange. may be problem in the board.
Apr 16, 2009 | Clarity C4230 Cordless Phone
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
Headset has static
Perform a reset on the headset.  Hold down the mute button (the dial on the back of the headset needs to be pushed straight in), and at the same time hold down the call answer button until you see the green light on the headset blink a few times.  Release both the mute button and the call answer button.  See if it works now.  If it doesn't, try a re-subscription (should be available in the manual).
Oct 24, 2008 | Plantronics CS70 Wireless Headset
GN Netcom GN 9120 Professional Headset Logo
70 people viewed this question
Top GN Netcom Radio Communications Experts
TO Lady
bigdawg7299
Tom Chichester
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
