Question about Mitsubishi Diamond WD-65831 65" Projection HDTV
Lines across the screen
We just changed the bulb, as it burned out yesterday. The picture looks great now, except for these dark lines that keep scrolling across the screen. Sometimes there is a purplish tint too. How do we make them go away?
    Sergeant:
  • 395 Answers
The dark lines could be what is called hum bars these are caused by ground differences between cable and your AC ground. check to see if these lines appear using a dvd and removing the cable from the cable box. if the lines disappear then call the cable company and your electricain. in the mean time you can use a plug adaptor that is the 2 prong (ground less) until you can have the problem fixed. but don't use the adaptor as a fix, for your TV is a computer and needs proper grounds.
Posted on Apr 14, 2008
Horizontal lines across HP laptop TE11HC screen - faulty screen?
If shown during the boot up process then you have a physical damaged screen.
Sep 18, 2014 | HEWLETT-PACKARD Computers & Internet
Horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Apr 09, 2009 | Sony KP-65WS500 65" Rear Projection...
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
White arched lines appearing on dark/black screens.
it sounds like you are seeing the vertical retrace for all three colors together (white). Its possible that all three screen adjustments (red, green, blue) are off, but I suspect a problem with the screen power supply.
there is also a recall on this set
http://esupport.sony.com/perl/news-item.pl?mdl=KP51HW40&news_id=24
Jan 23, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
PT-47WX, Blue streaks across the screen?
It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Hitachi 50in. Ultravision Model #50ux14b
Vertical output chip has some ring cracks on leads (cold solder joints). Set is shutting brightness off to protect5 it's crts from burning a black streak across them.
Sep 03, 2007 | Televison & Video
Jvc model av36230
you know its in vertical section, try to look for a capacitor and changed it, this is more of a capacitor problem.
May 16, 2007 | JVC AV-36320 36" TV
Ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
May 13, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Lines on the screen
i have a samsung rear projection , and it has red lines going across the screen. i put it in the back of my cuboard and went out to buty a new tv . now a few months on i got it back out to have a play with it and i coverd up the red bulb with something fireproof and now the picture is great again just that there is no red anything that is red looks a bit darker. its not great but a least its some use now and i use it in my bedroom. it mite not be much help but a least i dont have to keep it in a cuboard anymore.
Mar 15, 2007 | Toshiba 53H71 53 in. Rear Projection...
Mitsubishi Diamond WD-65831 65" Projection HDTV Logo
118 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
