Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator Side by side Model# PSS26NGSA
Stopped cooling. no noice. Electric inside fine, No ice , no water. All has defrosted. Inside temperature panel gives code HRS ? Help
  • Anonymous Apr 23, 2008
    Same scenario with mine. For the past month or so ice would only dispense intermittently. Now it has stopped cooling, controls are all blank and won't work, and I have the flashing HRS code. Wish I knew what that meant.
    Problem Solver:
  • 5 Answers
Sounds like motherboard failure take panel cover off and inspect you may even smell a burning like plastic smell on board
Posted on May 16, 2008
Admiral Maytag side by side model LSD2615HEW not getting cold. Fan runs. Clicks from the back every few minutes or so.
Its issue with compressor or the problem with defrost timer.It clicking to set the defrost cycle,but not actually working.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | Admiral 26 cu. ft. Side-By-Side...
Water leaking from bottom of freezer
Its defrost issue.The refrigerator is not defrosting on time,its defrost cycle is running late causing these problem.
Can be faulty defrost system parts or issue with defrost timer.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Dec 23, 2012 | General Electric GSH22JFX Side by Side...
GE profile side by side refrigerator wont defrost
Inside the fridge behind bottom drawers there is a heat element that has stopped working.You will see it is covered with ice.you will need to replace it and totally defrost both and restart.
Oct 23, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE side by side gss25jepbb not cooling any longer, probably 10-15 years old
HI LISA.getting old.could be a no of things.try these simple checks1-is motor making noise.(compressor).if not is hot?2- condenser is it hot or cold3- any ice at all inside freezer?if yes defrost all and try.(could be defrost timer/heater/t/stat/fan)4-if NOice it could be lack of refrigerant condenser fanmotor.or motor .hope this helps otherwise call engineer.good luck.Ali
Jun 24, 2012 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice is building up on my ge side by side refrigerator coils?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101,.,.,
Oct 06, 2010 | General Electric GSS22JET Side by Side...
Not cooling and building ice in the inside saface
heatman101
fgsjgf
Oct 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Temperature to warm
that is an automatic defrost problem
timer,heater or limit switch
Apr 22, 2009 | GE Profile PCF25PGW Side by Side...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Refrigerator stopped cooling
the back panel inside the freezer has screws in it. take out the screws to remove that panel. the coils are behind that. melt all the frost. youll see one or 2 heating elements in there also. replace the elements. its a common ge problem. this will fix the problem
Nov 27, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
435 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
