Master
- Posted on Jun 22, 2010
Re: The flex is cut. so it cant power... can i have a...
To fix this,
- Get a Torx 6 screwdriver,
- First remove the battery cover, battery and memory card.
- Run your fingernail around the edge of the join of the camera
surround and back cover to unclip it.
- Now remove the
two screws you
can see.
- Now run your fingernail around the edge of the front cover to unclip
it. You'll now be able to see two more screws. Remove these.
- Now lift away the keypad. It'll come away without much force. Again,
you'll reveal two more screws you need to remove.
- Pull the back of the phone away from the main body of the phone.
- Turn the phone over. Unclip the two metal clips by the middle of the phone
and a ribbon by the down left of the phone. The ribbon attaches like a plug and
socket. Simply lift it up to unplug it.
- A ribbon attaches the LCD to the PCB. Unplug this just like the
ribbon in the last stage. Now separate the phone into two parts again
- The ribbon you just separated is the flex you are trying to change, carefully replace it and your phone will be in good condition again.
- Reverse the whole
procedure for reassembly.
Take care
