Question about Dell Inspiron 6000 Notebook
No boot sector
I have a Dell Inspirion 6000. I get an error message on start up that reads: "No boot sector on internal hard drive." Is there any way to extract my information if the drive is corrupted?
  • matcat309 Apr 23, 2009
    I have a brand new Dell Latitude E5500 and when I turn on my computer from day 1 it says No boot sector found on internal hard drive. I press Control Alt Delete and it reloads and windows starts up. Is this a hard drive or a windows issue? I did all the checking and got no answers but since it is new if it is the hard drive itself I should get a new one. I do have the data backed on an external drive. I want to know if I should excercise my warranty or go through all the program reload etc that they want me to do first.
    Scholar:
  • 26 Answers
The other post is correct, but you don't want to try and take out Hard Drives from laptops.
The easiest option is to use a Dell XP CD for recovery
There is a little known fact though, there is a factory shipped Dell Partition that is hidden for recovery.
There is a tool (slightly technical) to 'properly' deal with repairing the MBR (as regular XP disks can ruin Dell MBR's)
Dsrfix Quick-Start This section should give you a quick idea how Dsrfix is used. However, be sure to also read the following sections to get a clearer idea of the details and potential pitfalls.
Dsrfix is a DOS program. It does not work in Windows. It does not work in a XP command-prompt window. It does not work in the Windows PE (preinstallation environment) or RE (recovery environment) -- those are not DOS. You need to boot to real DOS. If you need to, CLICK HERE FOR HOW , you can just download the 98SE DOS Bootdisk to a floppy.
This will get you into DOS (if you need that help) and then you can follow directions below)
It's a bit overwhelming, but it's the safe and real way
Download dsrfix.zip from DSRFIX LINK (Updated 09-20-2007, version 3.11)
  • Extract dsrfix.com from the archive.
    (Note to reader: The other files in the archive are supplemental. The only file you need to copy to floppy disk is dsrfix.com.)
  • Boot from your DOS boot disk.
  • Run the command " DSRFIX ". Review the results to assess whether your system is a good candidate for restoring Dell's DSR feature.
  • Optional: save a dumpfile before making any changes. This may be useful if you later need the information for forensic reconstruction.
  • If you decide your system is a good candidate for repairing Dell's DSR feature, rerun Dsrfix with the command " DSRFIX /F ". The program will repeat its summary report, then prompt you to queue any changes to be made. Accept or deny each fix proposed by Dsrfix. After proposals have been queued, confirm whether you want Dsrfix to go ahead and write those changes to your hard disk.
  • Rerun Dsrfix again for a new report to check the results.
If Dsrfix's report shows no fatal errors and no alerts, the Dell-specific restore feature should be functional on your system. You should see a blue "www.dell.com" banner across the top of the screen when the computer starts to boot. Pressing the Ctrl+F11 keys at that moment should divert the boot process to Dell's custom restore utility.
Hope that helps,
TrustMe
Posted on Apr 14, 2008
  • Trust Me
    Trust Me Apr 14, 2008
    Sorry about the link for DOS disk.
    Here (and choose 98SE):
    CLICK HERE
    Alternately, but using the same tool, this is a possibly, easier to understand set of instructions:
    Put
    the Windows 98 boot disk in your floppy drive (Drive A) and restart
    your PC, and from the Boot Menu select #2 Without CDROM support
    feature, as you do not need it, and you will boot up faster.
    When
    you are at the A prompt, replace the Windows boot disk with the second
    floppy disk, the one you copied the four files from the Dsrfix.zip file.
    1) Type:
    mbrsaver /s
    this
    will backup your existing MBR to "mbrsaver.bin" file to the floppy
    disk. Just a good idea in case something goes wrong and you can restore
    this MBR backup, by typing: mbrsaver /r mbrsaver.bin
    2) Next type:
    mbrsaver /r dellmbr.bin
    This
    will restore your MBR sector from the dellmbr.bin copy. You will be
    given a choice of which of the three parts of the sector you want to
    restore: the boot code, the Disk ID, and/or the partition table. Do not
    overwrite your partition table! Normally, you should not need to
    overwrite your Disk ID, either. So answer 'yes', 'no', 'no' to
    MBRsaver's three prompts, then confirm your choices by answering 'yes'
    to the final prompt.
    To make it easy and clear for you, here is what you will need to type:
    boot code : Y
    disk-id : N
    partition table : N
    write MBR sector now : Y
    You will now see: MBR sector restored successfully
    That's it, you have done it.
    Now
    remove the floppy disk, reboot your PC, and when you see the blue Dell
    logo at boot up, just keep the Control key pressed down and once a
    second tap the F11 key.
  • Dell Master
  • 1,183 Answers
Yes, you can extract information from the system, by removing the hdd and plugging it into a working system using a USB case. A local computer guy can help you do that .
You can also try to repair windows if you have the OEM xp cd sent from Dell
Dell inspirion 6000 is showing "loading PBR2.....done. NTLDR IS MISSING.HOW TO FIX
Use the Restoration Disk. When asked choose Repair.
(Non-Destructive Installation)
You are missing basic Windows files. Boot loader files.
Also you may have to prepare to replace the harddrive. May have bad Sectors on it.
Means I would copy off all personal information, after getting that laptop going again, or you may lose it.
Regards,
joecoolvette
http://en.wikipedia.org/wiki/NTLDR
http://computer.howstuffworks.com/hard-disk.htm
http://computer.howstuffworks.com/hard-disk7.htm
Dec 19, 2012 | Dell Inspiron 6000 Notebook
No boot sector on internal hard drive. No bootable
A boot sector is a sector of a hard disk that contains booting programs stored in the other part of the hard disk. You boot sector might have been deleted or corrupted and you can't logon until you repair or recover the boot sector. To do this you must have your OS cd. Boot from OS cd the follow below steps...
Windows Vista
1. Insert the installation disc.
2. Restart your computer
3. If prompted, press any key to start Windows from the installation disc.
4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
Boot from you hard disk then you're done!
Regards,
Jeep Brainy
Jul 29, 2009 | Dell Inspiron 6000 Notebook
Blue Screen doesn't load Operating System. I beleive there is a software conflict when my daughter downloaded an application she needed for university
If you are getting 'Uncorrectable data Error or Media' for your internal hard drive then it is likely that you have a disk problem rather than a software conflict caused by anything your daughter downloaded.
If the Dell diagnostics provide no solution, then you would need to use a specialist boot CD to try to repair the disk errors. One such disk is Hiren's Boot CD which can be downloaded as a CD image file (.ISO) from http://www.hirensbootcd.org/ then would need to be burnt on to a blank CD then the laptop booted from this CD.
On the initial Hiren's boot menu, select DOS programs, then select Disk tools before selecting HDAT2 to perform the disk repair actions.
HDAT2 can take some time to complete depending on the size of your internal disk drive and the number of bad sectors or other errors encountered - the tool will attempt to repair bad sectors by reading, verifying, writing and re-reading / verifying the data.
If the disk can be recovered, then you may be lucky and the system will be able to boot but otherwise, you may still need to do some further recovery work for the operating system, in which case you may need your Windows install or recovery CD media.
Dec 22, 2011 | Dell Inspiron 6000 Notebook
My dell inspiron 6000 wont boot up. error message Windows\system32\config\system is missing or corrupt
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Oct 26, 2010 | Dell Inspiron 6000 Notebook
''No boot sector on internal hard drive'' message on INSPIRON 6000
It does sound like the hard drive has died but the only sure fire way to check that is to remove it and try it from a proper PC using a cheap 2.5" enclosure.
If a normal PC can read it then it is more likely to be the hard drive controller on the motherboard which can be an expensive repair.
You can always get another drive if yours is pooched and you are not limited to the same size, You could get a larger one
You will however need an operating system.
Aug 14, 2009 | Computers & Internet
Dell b130 internal system restoration failed
Incase you don't have any thing important on the computer try a factory restore. This will wipe out everthing and make the cmputer like new. To start it power off the laptop. Power it on and hold down ctrl and tap f11 severl times at the Dell logo screen. Try this q couple of times as it may not work the first time. If this does nothing you'll need the os cd (xp cd) tO repair or reinstall windows.
Aug 07, 2009 | Dell Computers & Internet
No boot sectgor on internal hard drive
This is related to the boot sector file.So it wont work in the safemode also.Try and see that the hdd is detected in the system.If yes,then try booting thru th XP disc and run a repair
Mar 18, 2009 | Dell Inspiron 6000 Notebook
I bought a new hard drive, when i install in my pc there is no boot sector on internal hard drive, could you help me please.
If you use the Operating system disk and boot from cd,When you install,it will create the boot sector.
Jan 06, 2009 | Dell Inspiron 6000 Notebook
"no boot sector on internal hard drive"
i think you need to re-install your Operating System again since you got a new HDD wich is tottaly empty i assume so try to install your OS on the new HDD
let me know if it helped
greetings
Jan 02, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
3,277 people viewed this question
Alun Cox
