Question about HP Pavilion dv1000 Notebook
POWER UP I bought a new power cord for my laptop however it still does not start, do I need a new battery. Thanks
Remove the battery and just connect the power cord to the machine.
check if its powering on, if its not powering on then its most probably a mother board issue and will have to repaired
Posted on Apr 15, 2008
Won't Power On
Tree things to workaround:
1-RAM memory
Because the RAM is less expensive start by change one of the stick and keep testing otherwise turn up by your next shop.
Apr 12, 2013 | Dell Inspiron M5030 Laptop
New battery HP g61 is fully charged but not working \
Maybe the AC Adapter Power Cord is not working. If you can't get on the laptop with the power cord then it is bad and the battery might be drained so you have no power source to power up the laptop.
If the laptop works only off the Power Cord and the batteryis not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let thelatop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in andremove the power cord. If it won't boot or shuts down then the battery is deadand needs to be replaced if the power cord is ok.
Apr 30, 2012 | HEWLETT-PACKARD HP G61A50US 156 AMD Athlon...
Thanks for using FIXYA,
well, that sounds a motherboard problem, try to do this before we go furter:
take the battery off the machine and disconnect it from power, press and hold the power button at least for 30s.
then without the battery on , just the power cable, turn it on, if that dont works you need to repair the motherboard.
Thanks and dont forget to rate this solution
Anything else just let me know
May 27, 2011 | IBM Computers & Internet
Hello, I have an acer aspire 5741 which i bought 5 months back. The problem started a week back and has got worse. It is when i plug the cord for charging on laptop, the blue light on power button and...
it needs a new a\c power block inside they are cheap and semi difficult to repair i wouldnt think it would be over 100$ max but it isnt in my lap to inspect so this is my opinion ok
Dec 21, 2010 | Acer Aspire One PC Notebook
I have a Toshiba Satellite A105 laptop that will not power up.
Get sure the memories are good. then try reseting the BIOS by removing the BIOS batery, let it out for 5 minutes and place it again. Though you have to disassembly almost the whole laptop. If dont, chek the other "pheripheral" devices, HDD, DVD, and another (If)
Apr 20, 2010 | Toshiba Satellite A105-S4004 Notebook
I just bought a brand new battery and. left It
Connect the power-cord, and turn it on.
If the screen still goes dark, then the battery is *NOT* the problem.
If you can login and start Windows, *THEN* disconnect the power-cord, and see how many minutes that the battery will continue to provide power to the laptop.
Mar 26, 2010 | Dell Inspiron E1505 Notebook
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Bought new power cord for pavillon dv 1000 and
If the laptop runs on batter but cannot run on the AC adapter, you have a broken DC Jack. If you laptop cannot power up with the battery or flash low battery indicator, you laptop is dead.
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Laptop Not Getting Power
There could be a number of resons for this. Some thoughts:
1) Was your laptop working fine before you bought this new adapter? Eg. did it work with the previous one.
2) Are you positive that it is compatible? You should check all the power ratings against the old adapter (voltage output, current output).
3) Make sure the connector that plugs into the back of the laptop is a perfect fit. Connectors have a + and -. The outside metal ring may fit, but the inside 'pin' may be too small and not making contact with the receving part of the laptop.
4) Make sure that the connector inside the laptop has not broken. Easy way is to get a pencil with eraser and stick it in there and wiggle it around. If it moves sustantially, you may have some connector pins that have become unsoldered. If so, you need to get this fixed.
Apr 16, 2009 | Dell Inspiron 6400 Notebook
Acer AL1916 can't start
If you press the power button and nothing comes on at all then something isn't providing power to the laptop as it should and you may likely need to replace the battery or the power cord.
Find a replacement battery. Change your battery with a new one then plug it up and turn on to see if this works.
If replacing the battery doesn't work then replace the power cord and trying turning it on again. If this doesn't work either, you have a more serious issue going on.
Not too long ago, I was on vacation, my laptop had been working fine until suddenly it wouldn't come on at all. I went into the office to grab a new battery and power cord. (I work on computers so I had spare parts in my office/Tech Room.)
I got home and replaced the battery then tried to turn it on using the old power cord...didn't work. This was a brand new battery so now I knew that I could rule out the battery as the issue...the only two things left to troubleshoot were the power cord and the laptop itself.
I put my old battery back in the laptop then tried to turn it on using a different power cord and it worked. I didn't need to replace my battery or laptop. The power cord had failed.
I hope that your issue is as simple as this solution. Try confirming whether your battery and power cord are still may just need to replace one or the other.
Thanks for using Fixya.
Share your experience by rating this solution.
Mar 29, 2009 | Acer AL1916B 19" LCD Monitor
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
