Dryers Logo
Posted on Jun 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
WHY DOESN'T MY DRYER TUMBLE - Dryers
Anonymous
Level 3:
  • Master 713 Answers
  • Posted on Jun 21, 2010
Anonymous
Master
Level 3:
Answers
713
Questions
0
Helped
186443
Points
2287
Hi, If your dryer doesn't tumble,The problem might be from three different reasons,which are described below,check these:
1.BELT; Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
2.MOTOR; If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor: Remove the belt.Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor. If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
3.DOOR SWITCH; Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
Thanks and good luck
1helpful
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 04, 2016 • Dryers
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 • Dryers
Need to replace belt on vtd20g hotpoint tumble dryer
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 • Dryers
2helpful
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Went to dry clothes and the dryer doesn't tumble and all I hear is a click comming from the back of the dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Wt881 gorenje tumble dryer
Hello, I have a problem with the dryer, it doesn't dry to clothes off and everything else works fine. What seems to be the problem and how can I check it on my own? Is it the heather, the thermostat or something else maybe?
May 26, 2011 • Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Tumble dryer
If you here motor running, you have a broken belt. Give brand and model and I can help you change it.
Nov 21, 2007 • Dryers
Top Dryers Experts
john h
