Question about Weber Q Grill
Low gas pressure
After being outside all winter my Weber Q grill has very low gas pressure, barely enough to stay alight, not enough to cook on. I have attached a fresh propane cylinder, but that makes no difference. Might a nozzle or tube be blocked? If so, how do a clear it? Will buying a new part help?
Brian Taylor
St Louis
    Genius:
  • 1,447 Answers
Try this link for info's
http://www.weber.com/manuals/pdf_files/2008_updated/41005_112706_2008.pdf
Posted on Apr 14, 2008
    Master:
  • 555 Answers
Spiders like to overwinter inside the nozzle attachment. A blast of canned air should clear it out.
  • Matt Jurach
    Matt Jurach Apr 14, 2008
    Some of the models come equipped with a "Weber® Spider/Insect screen" that you can clean and replace. Check for your particular Weber Q model and look in the manuals found here for further instructions.
  • Matt Jurach
    Good luck, and happy grilling!
    *If you find the solution helpful, please rate it!*
MY FLAME IS TO HIGH EVEN WHEN I SET IT ON LOW
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Sep 08, 2010 | Weber Genesis Silver C Grill
My Weber Q grill worked great for 5 years but now it won't light on one corner and I can't get a high flame on any part of the burner. Even on "high" the flames are small & blue and the heat level is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 26, 2010 | Weber Q Grill
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
I have low flame on a weber gas grill. What are most likely causes and how to fix? Thanks.
Well it coulbe caused by these newer type propane tanks with the anti tip safety device installed inside them. To rectify you simply remove the tank to clear the pressure in the line and open all valve son the grill. Then close all valves on the grill and reconnect the tank. Then open the valve only just enough to allow gas into the grill, just crack it open a hair. Retry.
Oct 13, 2009 | Weber Grilling
Why is my natural gas grill not getting enough gas to cook in a timely manner?
plugged burners or low gas pressure are your only two choices.
Jun 15, 2009 | Weber Gas Go-Anywhere Grill
Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Jun 15, 2009 | Weber Genesis Silver C Grill
Not getting enough gas for high
There could be several things causing this problem. First, the burners need to be checked to see if they are stopped up. Grease and oils from grilling can clog them. Also incects like to make cosey homes in them over the winter months. Lastly, this problem could be the gas regulator going bad. Good luck!
Jun 05, 2009 | Weber Genesis Silver B Grill
Low gas flow - low heat
Hi Lyon,
Yeah, it's the regulator. Fortunately, they're cheap and easy to replace!
You can look on line for part number 80012. Or you can remove yours and take it to Home Depot or Lowe's in the outdoor cooking area and match up a replacement. <--- they're all the same... just make sure the compression fitting (the brass end) is the same size.
The only other thing I could recommend is this... Turn the LP bottle completely off. Then completely remove the big plastic knurled knob from the tank. Now replace the knob back onto the tank (all the way and make sure it's tight). Then S L O W L Y turn the gas back on. Now try your pit. If you get the same flame, it's the regulator. If you get full flame, you just reset the safety device inside the tank.
I'm betting regulator. Good luck and happy cookin'!
SG
Jun 03, 2009 | Weber Q Grill
My weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Mar 21, 2009 | Thermos Stainless Steel Gas Grill
Weber Q Grill Logo
280 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
