Question about Vacuums
My hoover is broken, the hooze doesnt **** the dirt.I emptied the bag inside, there is nothing stuck in it.I think the hooze needs to be changed, where can I do it in Dublin?
    President:
  • 1,673 Answers
You might check to see if the hose or the dirt inlet by the brush roll for a clog. Is the brush roll turning while you vacuum? If not, you may need a new belt. They stretch after awhile and turn the brush roll under load.
Posted on Apr 15, 2008
How to change the bag on a hoover hepa
There are different models with different ways to install the bag. The most common one is where the bag just pushes over the tube where the dirt comes into the dust compartment. Some have a paper bag inside a cloth bag with a variety of ways to attach the bag. For instructions on your specific model please include your model number.
Mar 06, 2017 | Hoover Vacuums
Not picking dirt and small items, doesnt to be working well.
make sure bag is empty and there isnt any cloggs in the hose or nozzle. If that is good, change the belt. these should be replaced every 6-12 months and when something gets caught in the brushroll
Apr 08, 2010 | Hoover U5264-930 TurboPower Bagged Upright...
Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Mar 04, 2010 | Hoover S3606 Bagged Canister Vacuum
Doesnt ****
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Jan 30, 2010 | Hoover U6311-930 Power Drive Bagged...
After I run my vacuum for a couple of minutes it shuts off. If I unplug the vacuum and plug it into a different outlet most of the time it will start working again.
I would say check inside the plug and make sure the connections are tight. If the vacume runs fine on the other socket outlet then it will bw a faulty socket which cuts your hoover out. Can buy a new socket frount from diy stores for about 2-3 pounds. If the hoover also cuts out on the other sochet it will be a temperature cut out device on your hoover. If this is the case empty the bag and give it a good clean and get rid of any accumalation of dust/dirt
Jun 24, 2009 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Apr 17, 2009 | Hoover Powermax S3530 Bagged Canister...
WIndtunnel TurboPower U5400-900 sensor light flashing even though I just changed bag
they do this as a matter of course. its a poorly designed vacuum. Hoover doesnt exist any more, it is actually a dirt devil
after years in the vac repair business, i reccommend that you look at panasonic the next time
Dec 06, 2008 | Hoover U5420-900 Bagged Upright Vacuum
Hoover Bagless
if the belt is more than six months old then change it even if it is not broken. then replace your filters if that doesnt work than check the hoses for a clog drop a marble down them and make sure it comes out.
Jul 22, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
