I have a malicious code found in the c:\windows\system.32\mijgh.dll infection: packed. win32.monder.gen
  • 333 Answers
Download AVG free edition and scan your PC - that should shift it. Also install Spybot and check your computer. Make sure you get the latest updates to these progs
Good luck
Posted on Apr 14, 2008
How to fix win 32 virus
It is hard to kill. Try these (second one if first does not work)
Jun 28, 2014 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the section. The application must also be compiled with debugging enabled. For example: <configuration> < jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful
May 29, 2010 | Dell Studio XPS 16 Notebook
How do I fix the dcom server launcher, the computer keeps shutting down after it's been on for about five minutes?
Click Here to Download this program (its free). Install it. Update it. Run a FULL scan of your computer (took about 30 minutes and the viruses didn't pop up until the very end of the scan). Delete ALL of them (note: you have to reboot to delete the ones in windows system 32) There will be a list of about 5-10 infections they should be similar to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\tdssdata (Trojan.Agent)
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
HKEY_LOCAL_MACHINE\SYSTEM\ControlSet003\Services\T cpip\Parameters\NameServer (Trojan.DNSChanger)
C:\WINDOWS\system32\tdssadw.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssl.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssserf.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssmain.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssinit.dll (Trojan.Agent)
C:\WINDOWS\system32\tdsslog.dll (Trojan.Agent)
C:\WINDOWS\system32\tdssservers.dat (Trojan.Agent)
C:\WINDOWS\system32\drivers\tdssserv.sys (Trojan.Agent)
Thanks for using Fixya!
Jan 31, 2010 | Computers & Internet
Loading problem
This kind of file extension is commonly used by malware and could well be an indication of an infection of your system...I got a hit on a search that this is a Vundo/Virtumundo virus file.
Please go to this link or this link or this link or this link (choose one) and follow the instructions given to either download software that will remove the malicious code from your machine, or scan your system with a tool that will report the details of the infection. If you need further help, post in one of those forums and a trained malware removal expert will guide you through the process.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Microsoft Windows Vista Ultimate Edition
When it scans and finds a virus it won't let me delete
Then if you can quarantine that in a folder. Quarantine it. If pccillin have a reporting log with its path. Then copy in a piece of paper the name and path. Then delete that in DOS mode if you are familiar with that only be sure that it is a legit viral file.
Apr 12, 2009 | Trend Micro PC-cillin Internet Security...
How to remove win32 downadup virus
go to and download spybot search and destroy,then goto and download malwarebytes antimalware,just click on the free green download button,after they are downloaded install them on your computer and run a full scan on the malwarebytes first,you have to go to settings to set for full scan,then run spybot,no special settings,when it isdone scanning just click on fix problems and that will take care of your virus.
Dec 05, 2008 | Microsoft Windows XP Professional With...
Windows XP System 32 infection removal problem
Download Spysweeper from webroot. They give a 14 day trial and it works great. I recommend paying the $30 and keeping the protection on your computer so it doesn't happen again.
May 31, 2008 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
