Question about Motorola Mobility RAZR V3
Using a digtital cam usb/wont install
How 2 transfer from comp
Aiptek camera transfer to cumputer
Using the PC Camera Function
1. Installing the AF Cam driver
You need to install the AF Cam driver before using PC Camera
or video conferencing function.
* If you have already installed the AF Cam driver, skip step 1. "Installing the AF Cam driver" and go to step 2. "Connecting your camera to your computer".
2. Connecting your camera to your computer
2.1 Turn on your computer
2.3 Insert the USB cable to the USB port on your computer
2.4 Insert the other end of the USB cable to the USB port on your camera.
* Then you can see the camera as removable disk. You can transfer the pictures from your camera to your computer like transfering files from one folder to another.
1. Go to camera folder
2. Select the file/pictures you want to transfer then right click and choose move option (if you want the files to be moved on your computer) then choose the desired target folder or drive.
*you can just copy the files form the camera to your computer too.
select the files that you want to copy then right click, choose copy then paste on the desired folder or drive.
Apr 09, 2010 | Aiptek PocketCam 3M Digital Camera
How to transfer video from my sony handy cam CCD-TRV418E to Comp
You can use a card reader to transfer your file from your handycam to your computer. Remove the memory card in your camera and insert it to the card reader and insert it to your computer to transfer your recorded video.
Mar 07, 2010 | Sony Handycam CCD-TRV418E Camcorder
Cam wont work with YM
since the webcam is connected through the USB, USB sometimes plugs off frequently. what is the resolution of the camera?
try to decrease the resolution. Yahoo uses very low pixel transfer rate.
decrease the resolution and try
Aug 17, 2009 | Logitech QuickCam Pro 4000 Webcam
Transfering files from comp to comp with usb...stuck...help
take the hard drive out of the old computer and put it in the working one as a slave. you will be able to drag and drop all the files you need.
Jun 18, 2009 | Gateway 310 Series (158920) PC Desktop
Sony Handycam DCR HC42 Video Capturing
you should be using a firewire cable to transfer video from cam to comp-cable comes 4 pin to 6 or 4 pin to 4 pin use 4 x4 for laptop and 4 x 6 for tower-make sure comp has port-not usb which is only for stills-once cam is connected or before open movie maker in vista and it should work or connect cam and computer should recognize it
Jul 26, 2008 | Video Cameras
Sound
I transferred the videos from the cam to the comp however the sound still isnt playing
May 30, 2008 | Vivitar ViviCam 5100 Digital Camera
JVC gr-d70 connection / uploading
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
May 23, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
Pc camera not working
did your digi cam, have an cd driver?..if you have that cd, you must install first...and then, will works fine if you restart and plug in your usb digital camera to the comp.
Feb 24, 2008 | Cameras
I cannot install my webcam
1 st of all install u r webcam in usb properly...
2.a massage will come on u r comp screen-(new hardware found)
3.now u r comp will ask to install driver....
4.install the cd in drive(cd come with web cam)
5.select automatic installation...
6.after compeation of installation u can use u r web cam....
best of luck.....write me again if any problem...
Feb 11, 2008 | Digital Products Monaco Ezcolor Photo...
Unable to transfer pictures
easier way to transfer these to comp is via bluethooth.
get a bluetooth dongle from an electronics shop, load it to your comp, pair phone to comp and then simply send via bluetooth from the phone to the comp.
No messy cables and works with all bluetooth phones ( ie not brand specific )
Oct 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
