Won't start My computer won't completely start. When I turn it on, the fan whirs a few times and then it shuts back down. Compac Presario PC130A
Sounds like u need a new PSU,
Posted on Apr 14, 2008
I have a emachine that powers ou, power pack fan, cpu fan but not the hardrive. It shut down and now won't start up. No beeps
Unplug from AC, open the case, clean if necessary, reseat the memory mods, use Electronic Contact Cleaner spray on contacts, plug in, push the on/off button. Does it begin to start, and in a few seconds completly shuts down? No LED's , no fans, nothing? Sounds like a PSU failure. Mine went out in 6 years.
Jan 09, 2013 | Computers & Internet
Compac computer won't turn on and the power light blinks constantly what can i do to fix this problem
Does it beep? if it does, whats the beep pattern...ie long long short, or short short short
if nothing else, something is causing a short...check the usb ports (real common) the contacts break from wear and short out, have your power supply tested.
Aug 20, 2012 | HP Compaq Presario SR1303wm PC Desktop
Compac fan wont work
Replace the fan. The system will overheat and shut down if the fan is not working. Most systems won't boot up it the fan is not working.
Remove the power cord, remove the case and see which fan is not working. On desktops there will be a fan in the power supply where the power cord plugs in and one that sits on the motherboard where the cpu and heat sink are located.
Get on ebay and order another fan based on your computers make and model.
http://www.ebay.com
May 04, 2012 | Computers & Internet
I bought a new charger for my laptop as my charger broke, and the little blue light comes on but the laptop won't turn on. I have the right charger, but it still won't turn on. The power light...
The first thing to do is check that the charger is putting out the correct voltage, which should be ~18 volt. Then try to start it without the battery.
If your voltage is OK and the battery out makes no difference, then I would suspect that you have a motherboard problem that must be fixed. If the computer starts up if you wiggle the DC plug where it goes into the computer, then it's the DC jack that is looks and must be re-soldered.
Sep 11, 2011 | Compaq Presario CQ60-220US PC Laptop
I have a compaq notebook model CQ61-412NR and i already have the usb fan hooked up under it, but it still keeps getting very hott and shutting down. is it safe to take the cover off the back to clean the...
When the CPU in the computer or laptopoverheats then it will shut down (i.e. thermal overload) and won't boot upagain until it has cooled down. If this is the problem is not fixed then theCPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Aug 22, 2011 | Compaq Presario Fan
My compaq CQ 61-420 US notebook won't turn on It was on and we left the room for a few minutes and came back in and it was off and won't come back on the 3 lights in the bottum left flash 3 times...
Greetings! Whenever you're dealing with a laptop computer that does not power up the first thing you want to do is disconnect the AC adapter from the laptop.The next step is to remove the battery from the laptop. Then reinsert the battery and reconnect the AC adapter. Press the power switch at this point and see if the laptop will power up normally.
Laptops are also prone to overheating. If the laptop powers up after it has cooled down and then fails again you may be dealing with an overheating issue. Try taking a standard can of compressed air and blowing out the ducts that supply fair to the cooling fan, as well as blowing off any "dust bunnies" or visible debris that have accumulated on the cooling fan itself.
Also make sure that the laptop is not sitting in an orientation that impedes the airflow to the cooling fan.
Jun 02, 2011 | HP Compaq Presario CQ61420us Notebook
I have a Compac Presario, running VISTA. When
simply disable the automatic update service by following these steps.....
start | run | services.msc | automatic update
stop ...and disable it...click ok
and close the service manager....
then try to shutdown the machine ....
Dec 30, 2009 | Computers & Internet
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
