Question about Myron & Davis AD-212 Car DVD Player
What to replace a ad255t with
This one has an internal short and what should I buy to replace it with
Disposal spins for about 5 seconds and then the circuit breaker trips.
Dear Jim,
Although you might be able to take it all apart, you might also find it nearly impossible to re-assemble, and find parts to buy.
I suspect you have a motor failure or a short circuit internally. It is possible water has gotten into the motor or controls also, causing the short.
My personal experience has been it will need to be replaced.
I fix these, and have changed out about 10 of them.
God bless your efforts.
Jan 08, 2016 | Garbage Disposals
Power cord fused out.no power to unir.worked perfect last week.can it be fixed?
Anything can be fixed or replaced. Question is if it is cost effective to repair. If compressor is internally shorted, you just go out and buy a new ac since the cost of repair is more than that of a new one.
Make sure that the short is not in the wire leading to the compressor before you go out and spend the scheckles.
Jun 12, 2015 | Amana AP095R Portable Air Conditioner
Where is the battery in 8 volt cordless drill
Did you give enough time to it to get fully charged before tring to work? It needs time.
Mar 02, 2015 | Craftsman 192 Volt Cordless DrillDriver...
Charging system
If the used alternator quit working then it\'s broke! Make sure your battery is not shorted internally as this could make an alternator work much harder than it needs to. Try getting the alternator repaired at a shop. Buying electrical parts at a junk yard is always a crap shoot...Chris
Jun 26, 2013 | 1991 Mercury Capri
I have sharp R 852 , when witched on here is a spsrk with a bad smell
You have and internal short to your magnetron or transformer, it time to buy a new microwave. This cost to repair can exceed the cost to replace.
Aug 28, 2011 | Sharp Microwave Ovens
Our Toshiba projection tv the screen is not coming on sometimes, I get it come back on by unplugging tv the plugging back in or unplugging the cords in tv looks like a distributor....need to know where to...
You can buy parts from
www.partstore.com
www.encompassparts.com
www.ued.net
www.searspartsdirect.com
www.sparepartswarehouse.com
for this site enter the part number from the part you are replacing into the search area on the left of the page
http://www.fox-international.com/
May 11, 2011 | Televison & Video
Caldera spas hot tub Olympic model blows circuit breaker trying to heat up
Remove all pwoer and then gain access to the heater probe. Read each probe from the center connector treminal to the metal base with an Ohm meter. There should be no reading. If you have low reistance the probe is internally shorted and will need replaced. It is a common failure for a heat probe. If the probe is bad when you do buy a replacement buy the "Coated" element. The extra $15.00 is well worth the investment in the overall lifetime of heating element service.
Replacement elements can be found here
Thanks for using FixYa.
Kelly
Mar 22, 2010 | Pool & Spa
After new stereo install, power windows, locks, heated seats and internal diming lights wont work. Fuses are ok. What can I do? muy first guees is that I shorted a cable somewere.
did you buy the installion wiring for the factory connector if not that would be the problem just replaced a customers wiring harness in his dash for the same problem so be ware
Oct 26, 2009 | 2000 Jeep Grand Cherokee
Myron & Davis AD-212 Car DVD Player Logo
Top Myron & Davis Car Audio & Video Experts
noagge
xxxxxx xxx
Tom Chichester
Are you a Myron & Davis Car Audio and Video Expert? Answer questions, earn points and help others
