Question about AT&T Merlin BIS 10 Phone
BIS-10 Phone - How to change default line
I have a Merlin Plus phone system and have a BIS-10 phone. ... When I pick up the receiver/headset how do I change the line that is used? .
  • 105 Answers
If you have a "squared" system (each line assigned to a different button), just press a different line button. To change the order of the lines, slide the "T/P" switch to "P" and press the line buttons in the order you want to use them (ie: Line 4, Line 3, Line 2, Line 1).
If your lines are "pooled" you just get the next available line from the pool - no choosing which line you get.
Hope this helps.
Posted on Jul 26, 2010
SOURCE:
How many lines does the at&t bis-10 phone have?
It depends on how the control unit is programmed. The BIS 10 can't be used as a stand-alone phone (as in....you can't connect it directly to a telephone line).
The BIS 10 will work with the following systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (with the proper modules installed)
AT&T Merlin Legend (with the proper modules installed)
Jan 27, 2011 | AT&T Merlin BIS 10 Phone
Will the AT&T Merlin BIS 10 Phone work on my home phone line? I work from home and love this phone, but need to know if it will work with a regular phone cord to the jack. Thanks!
No.
The BIS 10 and related telephone units need to be connected to one of the following AT&T Merlin telephone systems:
AT&T Merlin 206
AT&T Merlin 410
AT&T Merlin 820
AT&T Merlin 820D2
AT&T Merlin 1030
AT&T Merlin 3070
AT&T Merlin II (With the proper modules installed)
AT&T Merlin Legend (With the proper modules installed)
Oct 20, 2010 | AT&T Merlin BIS 10 Phone
I can't turn on the ringer on my AT&T BIS-10 Merlin phone. My line blinks green when a call is incoming and I have to pick up and press the button in order to receive the call. I need the phone to...
Depends on what system you have that phone installed o.
If Merlin Legend, on the left side of the phone there is a 3 position switch. Its in the middle position now.
Slide that down
press on of your lines
Press *347
Slide the switch to the middle position.
If that doesnt work, we need to know the system you have these phones on.
Aug 24, 2010 | AT&T Merlin BIS 10 Phone
Hi, We just purchased an AT&T Merlin phone to replace an old one on a multi-phone line. I'm wondering if I'll need to unlock and re-assign the mailbox to the new phone. And if so, will my boss lose...
Al the programming for the phone and voice mail are held within thier respective systems. Changing one BIS 10 for another will not delete any programming.
Aug 13, 2010 | AT&T Merlin BIS 10 Phone
What is the code to program a Merlin BIS-10 to have only (1) incoming line. I have a 10 button phone and it thinks there are (5) incoming lines?
Enter admin mode:
Slide switch on left (T/P) down to the "P" position.
press the intercom button above TRANSFER
dial the 2 digit extension number you want to modify
Touch the buttons to add/remove the lines.
Green light on means line is active
Green light off means line is not active
Mar 24, 2010 | Avaya Merlin BIS 10 Corded Phone...
Can I make the Merlin BIS 10 Phone able to use a
Yes, Plantronics sells a myriadof different headsets that should work well with Merlin sets.
Sep 10, 2009 | AT&T Merlin BIS 10 Phone
Lines 1 & 3 won't break dialtone on Merlin 410
Unfortunately no. The merlin 410 was an early phone system that didn't have much in the way of programming.
I HAVE AN ATT MERLIN 410 SYSTEM.ON ONE OF MY
At the phone slide the T/P switch to "P"
Press ** (star,star)
press the linjes in the order you want to pick them up.
Slide T/P switch to "T"
Jun 25, 2009 | AT&T Merlin BIS 10 Phone
Merlin Plus. Have two extra line buttons
do you have a manual? the programming code escapes me...you need to remove the lines on that phone. it wont let you program a button over a line button, so you must first remove the "Line appearances" then you should be able to.
Let me know if you need to code for the removal of line appearances....
May 18, 2009 | Avaya Merlin BIS 10 Corded Phone...
AT&T Merlin BIS 10 Phone Logo
420 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
