SOURCE: Water freezing on the tray section under the freezer drawer.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
SOURCE: Samsung RS253BASB leak at bottom veggie drawer
I had the same problem. I called tech support and they were no help. Being a handy man I dove into the problem myself and discovered the problem. If you want this solution, I have pictures and information. Simply email [email protected] and I will send you this infomation.
SOURCE: deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
SOURCE: Hi, i have a GE Profile PFSS6PKWBSS that leaks
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101.
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
