SOURCE: Mising printer driver
Here you go:
ALL IN ONE INCLUDERT MANUAL FOR THIS PRINTER
http://www.opendrivers.com/freedownload/218544/kyocera-fs-series-printer-kx-driver-v2.3.0607-windows-2000-xp-server-2003-download.html
RATE ME AS FIXYA PLEASE IF U GOT HELP!
SOURCE: Service manual for a Kyocera KM-C2230 Copier?
Here are the manuals associated with that copier: http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=13007&pcat=10565&rcid=10009&rscid=10028
Hope that helps you out!
SOURCE: Printer will only print page 1 of multiple page documents
1. Check that you are using the latest print driver - from kyocera website.
2. If the issue is when you print pdf files then make sure you set the printer in KPDL Auto mode - check the print driver settings about this and the printer menu.
3.You may check if you have the latest firmware installed within the printer - print a service status page (Menu->Others->Service).
SOURCE: kyocera 1620 error code c-4 000
that code, unfortunately, means your laser unit has went south. you definetly have to call a tech on this as it is quite a job to even get to the laser.
hth
razors
SOURCE: Kyocera 3800N Defaulted To MP Tray
paper guide was set at A5, then this allowed menu to change feed tray selection
