Question about Epson Stylus CX6600 All-In-One InkJet Printer
Print problem on CX6600
When I print a copy, some of the lines of writing are fine but then it will miss half lines or full lines and further down the page it prints alright again.
It has just had a complete new set of genuine Epsom cartridges fitted and they "charged " ok.
Any suggestions.?
  • Wagoner Apr 18, 2008
    When printing documents prepared on my computer, there are horizontal bands that leave out lines of typing or half lines.I have tried to minimize the lines by following instructions obtained on the internet, but the lines remain.
Bonjour
je te pose une question
epson stylus cx6600 est tres bonne qualite mais ici en algerie est introuvable pourquoi?
malgré ete tres demandez dans le marche algerien
en fin j'attende votre repense
voci mon email eplf210@hotmail.com
merci
Posted on Apr 16, 2008
Printer does not print good copy after doing several head cleaning operations and having enough ink in cartridges.
If the print has horizontal lines of 'missing print' do three head cleqans don't move the printer or switch it off, now leave it overnight - letting the head soak in fresh ink- in the morning, do one more head clean and then print the nozzle check.If it's poor photocopying it is most probably because the print quality for photocopy is set to a low setting. The manual will explain how to change photocopy print quality. Hope this helps
Feb 20, 2010 | Epson Stylus CX6600 All-In-One InkJet...
When copying in black only the quality is very poor in spots - in color it prints fine. I've already done every maintenance on the nozzles that is available. The poor quality is part of various lines are...
The print head is clogged.You can try unclogging manually.WARNING: next steps may lead to a defective of print head, try on your responsibility.
Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 08, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Not getting clear print , parts of lines faint or missed, hard to read copies, seems to be bottom half of line,every 4th line
ink low, dodgy ink, or head is wearing, blocked and cant get enough ink to paper, try with manufactures ink, but more than likly the head is block no easy fix, normally a write off, once in a blue moon after much effort one can clean the print head, total sttrip down and windex or metho the print head once removed but be prepaired to work on it for 1/2 a day, get covered in ink, with a good chance of getting nowhere...I'd try fresh ink then I'd quote you more than its cost..labour intesive..sorry
Nov 07, 2009 | Lexmark X5150 All-In-One InkJet Printer
This printer has not been used much since it was purchased 4 years ago. The black ink will print/copy, but misses about 2 lines in an alternating pattern. I'm new to this machine. Have cleaned heads,...
Ink cartridges don't do well when you let them stand for long periods. The ink dryes up on the print head. Try taking out the cartrige then take a damp paper towel with hot water (microwave works great for heating it up) draw the print head over it several times until you see ink flow evenly. them take a dry paper towel and draw the in head over it the same amount of times and reinstall. If doesn't solve the problem you may need to replave the cartridge.
Sep 21, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My dell 924 printer is only printing the bottom half of a line can you help me please ?
hi  andrealangto :
first , what r u trying to print ? a documnet /photo /email/ greeting ...?
*2 make sure the printer s working fine ., make a copy and it that comes out fine then the problem is with the file u r trying to print or as in most cases ., we need to reinstall the printer drivers .
reply to me for further help and support ...
hav a goodday !
Jul 15, 2009 | Dell 924 All-in-One InkJet Printer
CX6600 prints black lines through out documents
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Now try to Print it should work fine.......... Still same Problem Catridges Defective......... Good Luck...........
Jan 19, 2009 | Epson Stylus CX6600 All-In-One InkJet...
No error code
there is a prob in the transfer unit, you need to send this to a shop or call for service
Sep 22, 2008 | Xerox DocuColor 12 Printer
IBM Wheelwriter 30 series II - prints only half a letter
If it types only the top half yhe platen is probably not all the way in. Make sure the 2 black latches are lined up with the side frames then press down firmly on both sides of the platen.
DickyO
Apr 14, 2008 | IBM Wheelwriter 30 Typewriter
Cx6600 plenty of ink but none on the paper ?
since u just got it, consult the manufacturer immediately for more warranty options
Jan 21, 2008 | Epson Stylus CX6600 All-In-One InkJet...
CX6600 horizontally cuts text
Change the colour of the text to print each colour The same text once in each colour- then you will know what the faulty colour is. Download this utility www.ssclg.com install it and learn to use it. Also go to www.fixyourownprinter.com and take a look At #Epson printers there
Jun 16, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
227 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
