Question about Vacuums
My bissel 7901 won't spray water out of the bottom or hose to clean the carpet. I did smell a burning smell and shut it off. Is the pump gone?
    President:
  • 1,673 Answers
Depends, if the the smell was like rubber, then it may be the pump belt. If it is ok, then the pump could be bad, altho the pump wouldn't have had a burning smell. The main motor would if it was an electrical smell.
Posted on Apr 20, 2008
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Bissell carpet shampooer
HI,
Please check these:
• tanks are not sealed into receivers
• faulty auto load receiver
• pinched/clogged line
• defective component allowing air into system
• pump not mounted so it can move freely
• defective bridge rectifier
• clogged heater
• defective pump
• defective circuit board
* spray nozzles are clogged
Jul 20, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell7901 is spraying water out by the wheels
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101 sfdgd
Mar 28, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat Pro-Tech #7901 will not spray any liquid to the carpet and red cross indicator is not turning,but comes out of attactments
The 7920 is a 220 volt version of the 7901. I found a shop in New Zealand of all places that has service manuals on line. They are sort of picture books, but using them has saved me a lot of money as it makes repairing much easier. Here's the link you'll need. Good luck. If you need any more help, just add a comment to your post and it will go to my e-mail and let me know. The heads you clean are just the outlet spray heads when they get gunky.
http://newzealand.bissell.com/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Looks like you already have the USELESS Bissell advice list!
Jun 03, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
the water head are pluged use a tooth brush and some hot hot water and brush it on the tips until they are unpluged
May 06, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My steam machine will not spray water on to carpet why
clean the heater out it may be clogged with dry soap and water
Dec 28, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
No spray
pump part number is 2107181, the diverter valve # 2136988. You can Bissell and they can tell you who may have parts near you, or you maybe able to order thru Bissell.com. Before you took it apart, were you getting water to spray out of the hose. If you were the the heater is plugged and won't allow water to spray out the bottom.
Feb 26, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Singer by ryobi turtle plus carpet cleaner model ms4000
Will water squirt out the hose? If it does then the heater in the handle may be clogged and not allowing water to flow. The heater is in the handle. There are a number of things that can cause your problem. If no clogged heater and lines, and no water from the hose, then the pump or pump belt maybe bad, the cap for the flow indictor is leaking air and not sealing, the gasket at the bottom of the tank isn't on the tank, either missing or sitting in the hole in the base where the tank sits.
Here is a link you may find useful:
http://bissell.com/images/Schematics/7901.pdf
https://bissell.com/NewsLetters/ListArticles.asp?Page_id=27960&Article_id=132
Feb 21, 2008 | Bissell 7901-7 Proheat Upright Vacuum
Vacuums Logo
259 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
