Question about Canon NP 6050 Copier
Canon 6050 copier
My machine after 2 copies it indicates massage paper jammed,you have stop then start again thats after 20 to 30 minuts.again after 2 copys it says paper jam massage
iqbal visram
  • 3 more comments
  • Anonymous Apr 21, 2008
    even if you make one copy it inticatets paper jam
  • khota May 10, 2008
    One copy from deck is passing alright but when we do 2 copies, after every one copy 2nd copy is jammed on the vertical roller. Evern I have cleaned the vertical clutches/ conveyor rubbers. Changed the Foam/Ruber seperation rollers. please suggest what should I do next.
  • Anonymous Apr 25, 2009
    I have one problem and I need your help:I have completely white copy,I tried to press button for darker copy,nothing or something little has change,I hardly could read the text.Thanks for solution,it is very important for me
  • Syed Osram
    Syed Osram May 11, 2010
    How many copies do you want to make ? 2 or more than 2 ? How about just 1 copy instead, is it indicates same message ?
  • Anonymous Mar 20, 2014
    The paper has jammed
Clean the rollersinside for paper pick up, might be dusty thats why its slipping
Posted on Apr 27, 2008
E717
Posted on Apr 21, 2008
Yes it indicates same message
Posted on Apr 18, 2008
The out copied paper is not fully copied
First turn off at the wall outlet and count to 20 and plug back in to reset.
If that doesn't work, it sounds like there is a zoom feature and it is set to copy at 110%, making it too big to fit on the A4 paper and it is continuing on Page 2.
Jul 29, 2017 | Canon NP 6050 Copier
Can not copy two sided.paper always jam
Check for some obstruction in the paper path where the paper stops. There can also be paper cuts in some of the sensor arms that may be giving hesitation delys csusing the jams. Jam codes in service mode will also help isolate the problem to a more specific area.
Jun 17, 2011 | Canon NP 6050 Copier
After restarting the machine shows the ready to copy massage it later bring a red indicator without any massage on the screen but the lower massages remain such as copy ratio, density among others what...
did you check jam indicator that glows red left from LCD panel?
Try to reopen the paper drawer and put it back strongly.
If you have dadf it can show jam if its lift up all the way.
On leftsideway, beneath the left door is paper pick up door reopen them and close more strongly.Also check the sensor flapper in the middle, wich is seen when paper pass door are opened.
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 04, 2010 | Canon iR 2016i Black and White Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Canon NP 6050 Paper Feeder won't feed
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
Apr 01, 2009 | Canon NP 6050 Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
actually u hv not putted ur pblm correctly...
paper is jamming in ur machine but fm which tray u r taking paper...
n e way ...
1..if paper is comming fm down trays (i.e. 1,2,3,..or4) , try to clean the Pickup rollers of rubber material (at down side to the duplex tray or upside to the each tray) with some water and smooth cloth
2..if paper is comming fm bypass section then ur bypass pickup roller must be cleaned like above, or it must be replaced...
....try this and then also if not solved then place ur question again in detailed..
bye
Aug 15, 2008 | Canon NP 6050 Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
Canon np 6030
Is it looking for toner or is there still a jam in it. You may want to try to turn it off and unplug the sorter and turn it back on. If that dose not work turn off again and unplug the adf and turn it on again. If that dose not work if you have unplug the bottom 2 trays. If one of those is causing the problem look deeper in to one of those units. Also, will it showw or flash a error code on the display?
Mar 18, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
149 people viewed this question
old marine
old marine
