Question about Fisher Paykel Eco IWL16
Washer won't spin or drain
My washer stopped working properly this weekend. It fills with water, will rinse on rinse 2 but will not spin. It's full of water. Anyone know how I can get it to drain?
  • 1 more comment
  • LHPinNC Apr 14, 2008
    sorry, it's a fisher and paykel iwl16. It's only 11 mos old
  • Anonymous Jul 06, 2008
    I have a fisher & paykel 7.5kg smartdrive washing machine. It wont drain. It wont work on the 1st rinse cycle, nor the spin cycle.
    I ahve ahd this problem a few years ago and a technician said I could reset the system by pressing some buttons together on the panel, but cant rememebr how, can anyone help??
  • Anonymous Mar 15, 2014
    ecosmart washer not rinsing or spinning or draining
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
Whats the make of your washer, if its the older models it might be the lid switch, switch might be defective, but i still need the make/brand of the unit to be more specific.
Posted on Apr 14, 2008
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Water fills to proper level but agitator doesn't come on instead there is a grinding noise, when I move control to just prior to rinse cycle water drains properly, but still just grinding or buzzing n
Hi, Do you know if the washer spins at all?
It sounds like the coupler has gone bad.
Please let me know if it spins at all.
I can send yyou instructions on changing the coupler.
Vic
May 28, 2009 | Whirlpool LTE6234D Top Load Stacked...
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Machine will not agitate for wash or rinse cylces
that could be your problem or your drain pump maybe full... try spin and drain see if it will drain
Sep 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
Fisher Paykel Eco IWL16 Logo
359 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
