Question about Tech Solution TS-8000 Cross-Cut Shredder
Sheadder noise Making loud squeaking noise needs greas or oil
  • 329 Answers
All shredders need special shredder oil applied to the gears at least once a month. Oil is a very sticky silicone. Office supply stores sell it...
Posted on Jun 24, 2008
Car intermittently making very loud soud. Cannot describe it other than the car just sounds loud. No grinding or squealing. Just loud. I'm pretty sure my compressor is bad, but I am not using the AC or the...
Is it squeaking noise, Loud rubbing noise? Brake problems? Clanging noise is bad engine problem. Was oil that low that they needed to add it. Have you checked it again since that? Do so immediately, If low, take it back NOW.
Dec 05, 2014 | Cars & Trucks
How to fix a belt that is making a loud noise on a 1994 Ford Taurus
If it is a loud squeaking sound, the belt is stretched out too far for the tensioning pulley to take up the slack. Check if the belt has grease or oil on it. If it does find the cause, fix the cause and then change the belt...there is no tension adjustment to be made,
Jan 14, 2013 | 1994 Ford Taurus
A loud squeak
-the canon laser shot LBP-5200 printer is making squeaking noise most likely the printer needs cleaning or oiling as well, if you are not familiar w/ the cleaning or oiling it up, you can bring it to a local repair center, if it is still in warranty w/ canon you can call them up and have them fixed that printer for you.
link for cannon support page: ""
Feb 25, 2011 | Canon LASER SHOT LBP-5200 Printer
My Kenmore 12493 is making a loud squeaking noise. I have oiled the machine as per the manuals instructions...I can not figure out where the squeaking is coming from.
If you are good with machines you need to take off the bottom cover and oil all of the drive. The motor may all so need to be oiled.
Good luck
Dec 31, 2010 | Kenmore 15208 Mechanical Sewing Machine
Blower fan squeaks loudly, how do I oil it?
The blower wheel is plastic I do not think oil will quite it down. It may be a little loose and rubbing the housing making noise,
Sep 09, 2010 | Kenmore Dryers
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
Makes loud squeaking noise, cuts off after a few minutes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Loud Squeaking Noise kenmore gas dryer 80 series
You need to change your drum rollers. To get to them you take the dryer apart from the front not the back. There are 2 screws where the filter goes in on top. Then pull the top toward you and up. Then remove the 2 - 5/16 inch screws on each side of the front panel about 2 to 3 inches down. Then pull the front up and out. Then you will see everything. Replace the belt, drum rollers, and idler making sure to oil each as you re-install them. Then put back together and your on your way.
Dec 07, 2007 | Kenmore 63942 Dryer
Tech Solution TS-8000 Cross-Cut Shredder Logo
388 people viewed this question
Top Tech Solution Office Equipment & Supplies Experts
Michael Galve
Michael Galve
Jim Keysor
Are you a Tech Solution Office Equipment and Supply Expert? Answer questions, earn points and help others
