Question about Canon imageRUNNER 5570 Copier
Deleting users out of the mailbox
I have some users in the mailbox option that need to be deleted. There are passwords to the mailbox that are unknown so that makes this difficult! If you know how to do it...please please please help! I called customer service and they were no help to me!
  • Canon Expert
  • 287 Answers
Hello Credman,
Ok, you may want to consider all other input and options but I feel quite confident that there is only one option. The fact that "passwords" are involved is the true obstacle. In the past, the term password did not mean as much as it does today in regards to security. In fact, some manufactures require replacing circuit boards, with deep technical support from the vendor to maintain serial numbers and copy counts to make sure no one tries to commit "lets call it odometer fraud". I know it sounds crazy but these are the times. What I can offer will dump every shred of customer customization from the machine. As if it were new. The meter remains the same. However, ALL other customization will be lost. IP address, one touch,favorites,fax numbers........etc.....GONE. If you are cool with that then here we go. Press the 'additional functions" key, then hold down the the numbers 2 and 8 simaltaneously then back to additional functions.This is a fluid 3 step process.1,2,3. This will summon the service mode. A place where you can REALLY %%^@ things up if you feel like it. But we will follow a straight path to where we need to be, ok? Once you have executed the afore mentioned steps the screen will change and give you a menu of items that varies depending on the accessories your machine has. At the top will be " COPIER". Press copier. Now you will see a new menu with an array of tabs across the top of the screen. Press "Function". New menu appears. You will see a box that says "CLEAR". Press it. Another new menu will appear. We are looking for "MMI" which typically appears on the second page which you can access by pressing the right arrow at the bottom of the screen. Depending on the machine configuration "MMI" might appear on the first page, but rarely. Once you have found MMI, press it and it will highlight,then press ok at the lower right hand portion of the screen. You may retain the better part of your "fax" info if you have the fax option but I just wanted you to know you "could lose" any pre programmed stuff. Canon says you won't. Ok at this point you have cleaed the customer memory and you will need to press the reset button as many times as you need to to return to the main screen. Then, we need to shut the copier down in the proper sequence as per usual...WHICH IS.........press the on/off button on the operator control panel and keep it pressed until the screen guides you thru the shut down sequence. Again this will vary depending on a number of things but the copier will guide you. And if it questions you whether you want to "FORCE OFF" just say yes. At the conclusion of this dance , you be asked to turn the main power off. The switch is located on the right side of the copier, toward the rear , slightly lower than halfway down. Power off and wait a few seconds and then power back on. The dance is complete.
Posted on Jun 29, 2008
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
Tip
How to reset your Virgin Mobile voicemail
Hi Virgin Mobile Users! Since your password is private, Virgin Mobile don't have any record of it. Don't worry you can still reset your mailbox, you can recover your password by doing the following steps below:
  1. Please press and hold the 1 button on your mobile.
  2. Then choose one of the following options.
    • If you have "password skip" turned off, you'll be asked for your password. Call customer care at 1.888.999.2321 from your mobile to reset your mailbox.
    • If you've got "password skip" turned on, press 3 for personal options.
  1. Press 3 for mailbox settings.
  2. Press 4 to change your password.
  3. Choose one of the following options.
  • Enter a new password (4 - 10 digits long, numbers only) then press #.
  • Press 0 to find out what your current password is. Then press * to keep it
Although, with the password reset, all your previous voice mails will be deleted and will no longer be retrievable. Hope this helps.... please don't forget to rate! thanks!!!
on Feb 06, 2010 | Cell Phones
No one can leave messages as my mailbox is full -
Call the voice mail system from your phone (usually ext 165), put your password in, and start retrieving messages. Use a lot of 3's (delete) and it will get it down. IIRC you are only allowed about 100 or so but it is set by VM class of service.
Carl
Aug 12, 2009 | Panasonic KX-T7431 Corded Phone
N97 doesn't delete mails. I try to delete mails, I get a box that says "deleting", but it freezes there, and the mails aren't deleted... :-(
see here is the solution.. go to messaging->options->email->mailboxes->select ur emailmailbox->options->delete mailbox
THen configure your mailbox again
Aug 06, 2009 | Nokia N97 Cell Phone
I have a Partner-18 and need to reset the password for a user
Delete the mailbox for this extension then re-create entire mailbox.
May 04, 2009 | Avaya Lucent Partner 616 Phone
When attempting to retrieve messages it indicates the mailbox is locked.
Which mailbox? Just a users or the system admins mailbox?
If a users, you can go into system admin and modify the mailbox, one of the options is to default the password.
Dec 20, 2008 | NorStar Meridian M7310 Phone
Need to change user name and domain on Outlook email account
You cannot modify your existing ActiveSync partnership.
You must go into ActiveSync options on your phone and delete the partnership.
Note that deleting the partnership only deletes the copy on your phone. It will not delete the source mailbox on your server so don't worry.
Once that is done you can set up the new partnership with your new server.
I hope this helps.
Oct 16, 2008 | Samsung Blackjack SGH-I607 Smartphone
Old Unknown Password for Voicemail
Unfortunately the passwords can not be seen and the only solution is to delete the mailbox and re-install it. Your Admin Assistant should be able to add and delete mailboxes. Sorry, Let me know if you need help with deleting and adding the mailbox. .....Mitelmike
Oct 13, 2008 | Samsung Phone PDCSLCD12B
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
Sep 18, 2008 | Panasonic KX-T7731 Corded Phone
Lucent Technologies 1725 answering machine
Taken from the 1725's User Manual:
Deleting Messages
1 Connect with the answering
system.
2 To delete selected message
— Press
and release 3 while the message is
playing.
To delete all messages in a
mailbox
— After you have listened to
all messages and heard the two beeps,
press 3, and then the mailbox
number.
You can download a copy of the manual at the following URL:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=164
Jul 15, 2008 | AT&T 1725 Answering Machine
Canon imageRUNNER 5570 Copier Logo
225 people viewed this question
old marine
old marine
