Question about Whirlpool LHW0050PQ Front Load Washer
After washing the washer will not go into the rinse or spin cycle but if I put it in the spin cycle manually it will work, and if I put it in rinse cycle manually it will not work. Would the problem be a control switch or the circuit board?
  • 4 more comments
  • Anonymous Apr 22, 2008
    I have a similar problem. The washer will sometimes start the wash cycle but even at the best of times only seems to get about half way through and then switches to done. It never gets to the rinse or spin. I can manually set it to rinse and some water will pour over the clothes but it doesn't tumble them like it used to and then stops before getting to spin. Even if set on spin it won't.
  • crapwash May 29, 2008
    I am now experiencing the same problem. The washer will go through a wash cycle but won't drain or spin out. My neighbors had the same issue and had to have all the boards replaced which seems to have fixed the issue for now. We all have washers that are less than a year old and are the LHW0050PQ. I've had the pump replaced but that still won't drain the water.
  • drichardson2 Jul 06, 2008
    washer does not spin when it reaches that part of the cycle. sometimes the cycle timer needs to be moved manually.
  • waudlob Aug 03, 2008
    The washer works fine till it reaches the spin cycle and never reaches "done". It will spin (without clothes), but still never reaches done, also I hear the pump motor running. Finally, I did check the water filter and it was clean (no lint, particles, etc).
  • golfer42 Feb 01, 2009
    will not go past rinse cyce unless I manually set it to spin and drain. Lost water the other day and followed the reset instructions (EXCEPT DID NOT UNPLUG)! What should be done?
  • Anonymous Mar 27, 2014
    no fast spin
I have a 2 yr old GE front load and had the same issues. I solved it by cleaning out the drain filter. (It is not listed anywhere in the manual) It was behind the bottom front panel. It looked like a plastic gas cap. I unscrewed it and it was filled with a huge amount of lint, tweezers, change and all other junk from my kids pockets. Apparently if the washers have to much water in them they will not spin out due to the weight. Once the drain was cleared out and the water was free to drain it worked like brand new.
Posted on Jul 28, 2008
Basically,the machine you have is garbage! - I have one also, It is less than one year old and the repair folks have been out 5 times. It doesn't spin either!
I'd call this one a lemon!
Posted on May 22, 2008
2 Suggested Answers
TheMobilian
  • 8205 Answers
SOURCE: Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
Posted on Jul 12, 2010
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
LHW0050PQ4 whilpool washing machine goes through wash cycle but wont rinse,spin or drain
According to the service manual, if the washer won't drain or spin the drain may be clogged.
http://www.searspartsdirect.com/partsdirect/user-manuals/27552/lhw0050pq4-whirlpool-parts-residential+washer-manual
Apr 04, 2014 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool front load washer Model# LHW0050PQ3 Which board do I need?
Sounds like possibly a bad control board.
Try to unplug your washer for 5 minutes then plug it in and run a load and see if it still does it.If not, you will need to replace the main control board.
May 11, 2012 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door to washer won't open
You just have to wait a few minutes after the spin cycle is over and the "done" light is on. At least that always works for me.
Jun 16, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washer fills with water, but does not agitate or spin rinse
This could be bad door switch or bad timer. You need to test it with a multimeter
Mar 31, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
599 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
