My kodak camera (Easy share Z1285) is stating 'Memory Card requires formatting' - Continue or Cancel? What should I click on to ensure I don't lose any of the pictures on my camera?
The DX7440 works with MMC and SD cards, which max out at 2GB. While your 4GB SDHC card fits into the slot, it is electronically incompatible and will not work with this camera. You need to stay with SD cards, 2GB and smaller.
I'm suspecting that you are trying to use a new 4GB or larger SDHC card with your older model camera. Please note that your model camera can only use 2GB or less standard SD cards (and NOT SDHC). 2GB SD cards are inexpensive, and still available on Amazon.com if your local store no longer carries them.
Hope you have this figure out if not here goes. Sounds as if the camera is caught in a feed back loop. As long as you have down loaded and saved your images on the computer go ahead and format the card. When it says delete everything on the card select OK and click the start button everyone is happy again. By the way all new card and card after doenloading to the computer should be formatted in the camera. Never format in the computer and deleting images one by one is just a great way to totally mess up a memory card's mind. Format, Format
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
You are probably using a 4 gigabyte memory card and your camera will only support a 2 gigabyte card. Get the right card and it will format properly.
Larry
