No other symptoms noticed. One day won't turn on. Plugged TV back into the outlet, Front power light (blue) comes on, then after about 3 seconds, there is a rapid "Clicking" noise near the power supply (where the cord enters the TV set in the rear bottom of unit), and then the set turns off. The screen is never engaged. I do have the unit plugged into a good APC power strip surge protector, which is operating normally. All other devices operating normally. Is this the power supply? Can I replace it?
Thanks a million. - Steve
1 Other User Has The Same Problem
Comment by kstar724, posted on Aug 28, 2008
I am having the same problem. I had a repair man look at it. He told me that it was the red CRT. There was liquid coming out of it. Well he was supposed to order the part and come back to fix it. He never showed back up again. His number is no longer in service. Now I am having trouble finding someone to work on it, since it was taken apart. Would like to get an idea of what I need to do. Thank you
Rating: 0%, 0 votes
On these TVs the power supply is rarely the cause of the shutdown. Something further down inside the TV has failed. Replacing just the power supply will not fix the problem. The most common reason there would be an overload would be in the high voltage circuit that lights up the 3 CRTs, next would be the coils around the CRTs that bend the beams to make the picture. This is normal circuit aging and wearing out. Unless you are very skilled with trouble shooting TVs I would recommend having a service center look at it. An authorized JVC shop would be your best choice because they will have access to the manuals and bulletins and have probably had other similar JVC units thru their shops.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for JVC AV-56P575 56 in. Rear Projection
Email this problem
Can you Help with these Projection Televisions problems?
Problems with JVC AV-56P575 56...
doesn't come on
