Question about Canon CLC 4000 Copier
ERROR CODE E000-0320
Could anyone tell me what E000-0320 means on Canon CLC 4000?, thank you for your help.
  • copired Apr 15, 2008
    I have the CLC4000 manual service but it does not appear the specific code E000-0320, I would like to know what "0320" means, thanks for your help. All lamps and thermal fuses work.
  • Canon Expert
  • 1,326 Answers
A E000-0320 code is a fixing unit error code. It is either not warming up or it is getting to hot. It is a thermister is shortting out or a thermal fuse or one of the heating lamps are blown.
Posted on Apr 15, 2008
  • CAPANEGRA Mar 11, 2011
    EL SWITH DE FUSOR HAY Q CAMBIARLO
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Canon irc2105 Error code E216-0000
hi i had a problem error code E810-0302 can you help
Mar 01, 2010 | Canon CLC 4000 Copier
Canon clc 4000 error code e194-0101
0101
When the pressure main thermistor fails to reach 80 deg C within the prescribed period of time after reaching 50 deg C during warm-up
you need your fuser rebuilt by a technician
Dec 29, 2009 | Canon CLC 4000 Copier
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Hi, can you please tell me what error code E000751-1301 is on a canon clc 3220, thanks Jane
E751, 1301 means there is an issue with the toner system. The machine is checking for the presence of toner. After 3 attempts the machine will go into the error. In this case, the yellow toner tube needed to be replaced even though the machine did not indicate to do so. The color that is causing the issue is the first digit in the sub code.
Oct 13, 2009 | Canon CLC 1150 Color Copier
I am looking for the Canon CLC 4000 service manual that I can download.
You might try www.justmanuals.com.It is a pay site but they seem to have everything.Good Luck
Apr 30, 2009 | Canon CLC 4000 Copier
ERROR CODE E020-02D0 on Canon CLC4000
you need a full developer change . do you know how to do that
May 15, 2008 | Canon CLC 4000 Copier
CLC 4000 FUSER ERROR?
The problem is that the lower fusing roller has shorted out and it may have shorted out the DC- Controler. Did you resently replace the lower fixing lamp. If yes it is wise to replace the dc- controler at the same time. A suggestion from a Canon tech pub... Good Luck....
Apr 15, 2008 | Canon CLC 4000 Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
616 people viewed this question
old marine
old marine
