Back to:
Tags:
Brother EM-530 Typewriter
No print - Brother EM-530
posted by Poteau on Apr 14, 2008
We put in a new correction tape. Now we are unable to get any printing onto the paper, although we can see the key is striking the ribbon as it leaves the imprint of the letter. We checked the button which allows for thick paper and it is in the right position.
We notice that the impact light is not on any setting. We have used the Alt + Impact (+ and = key) as well as the Code + Impact key and the light comes on, but as soon as we release the keys, the light goes away. It does not seem to take the command.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 24, 2008
Not Rated (0)
EM-530
Rank:Apprentice Apprentice
Rating: 100%, 5 votes
You need to take your ribbon and correction tape out and put them in again, something may have gotten crossed. I know I have done that before. (Sometimes one or the other is put in backwards)
If this doesnt work, you may want to try re-setting to the factory settings of the machine to see if that is your problem. Turn off the machine, hold the Code, Shift & Tab key all at the same time. Keep holding them down while you turn the machine back on. You will here a few rapid beeps. That lets you know it has reset. You will need to fix your margins and tabs to your liking again.
-If for some reason you reset and you get the wrong symbols when you type, change your keyboard setting back to "I" (lights at the top left should tell you if its under "KB" (Keyboard) I, II, or III) turn off for 10 seconds and turn back on. I hope this helps!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no print - Brother EM-530:
I don't want to Accept this solution
Can you Help with these Typewriters problems?
Typewriters
have been given Brother AX110 electronic typewriter but no...
Typewriters
I have a smith corona XL 1000 typewriter that i haven't...
Typewriters
Would like to continue where I left off last night with...
When typewriter turned on, pitch beeping noise will not...
I cannot get my to stop tabbing to the end of the page...
Loading problems.
Repair Service
Find Typewriter Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
