Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Print cartages won't move when I open to change.
I need to chang my ink, I open the printer but the ink cartages stay put - they should move so I can remove them - what is wrong.
    Problem Solver:
  • 14 Answers
You can manually move a printhead( the one that holds the cartridges) to the center. Open the door at the back, turn the wheels clockwise, and while turning, manually move the printhead to the center..
Posted on Apr 14, 2008
How do you put in new ink cartage
Usually - depending on the model of printer - you, open the cover and press the ink button. The cartridges will then move so they are in a position to be removed. They simply lift out.
The easiest way to find out is Google the make of printer .. i.e 'How to change ink cartridges on a Canon xxxxx'
Nov 05, 2015 | Office Equipment & Supplies
Why is my printer missing lines
I think you need to change your ink cartridge.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
How to I change ink on epson printer NX127 I cannot get the cartage out Can you show me the picture of the cartage ink holder with the lid up
First make sure the printer is on, then open the printer cover and the cartridge cover. Then press the Stop button. Assuming the printer has identified a cartridge with low ink, that cartridge will be moved to the replacement position; then the power light will flash. Squeeze the tabs on the ends of the cartridge together and lift it up. Unpack the new cartridge and remove the tape carefully. Then press the new cartridge into place until it clicks.
If more than one cartridge has low ink, the leftmost one will be in the replacement position when the cartridge carrier stops moving. Press Stop again to advance the carrier to put the next low cartridge into the replacement position. Then press Stop again to have the printer move the cartridges to the home position and charge the print head. When the lights go out or stop flashing, close the cartridge cover and the printer cover.
If the cartridges aren't low on ink, then use the Epson printer utility (under the Maintenance tab) to start the process.
For pictures of the Epson printer during ink replacement see: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_SessionID=@@@@1558177770.1297529968@@@@&BV_EngineID=ccdcademkhmjkgicfngcfkmdhjidfmh.0&cookies=no&infoType=FAQ&oid=150187&prodoid=63088089&foid=157388 . Alternataively, see http://files.support.epson.com/htmldocs/nx125_/nx125_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=Ink.7.1.html .
I hope this helps.
Feb 12, 2011 | Epson Office Equipment & Supplies
It will only scan not print
If you refill you Ink Cartage on this Please make sure the Ink is primed. If you touch a paper towel to the bottom of the ink cartage and the tale stays dry It is the cartage.
If that is ok Make sure that the door and the contact(If you can see it) Is closed and in good shape
Jun 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
Suddenly it wont priny black, have tried to replace with i new. Paper is offcourse removed, but it wont print black. Have run all cleaning programs. Could it be under the ink tank? How can i get to it?
Maybe you need new black ink cartage, or new color if its one pint cartage. follow the procedure under the bonet to change the ink cartages,. hope this helps
Nov 30, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Won't print color. Color inks are full, cleaned jets, but still won't print in color.Black ink prints.
Due to not used your cartage the opening of the cartage lid become freeze so put it for some time below running water and then try to print it will work
Nov 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
The timing strip drop off
you need to remove the covers and get to the carriage area and put back on the strip it just slots in on one end and usually a little spring and a metal piece holds in on the other end.
you would be getting error codes as it is as the print head doesnt know what position it is in
canon tech
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
107 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
