Washer will not stay balanced. Have done all of the usual things, ie, leveling, feet replacment etc. Still gallops all over the laundry room.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 42 Answers
WHAT MAKE/BRAND IS THIS WASHER. IF ITS THE OLDER MODELS IT MIGHT BE THE TUB SPRINGS IN THE INSIDE.
Posted on Apr 14, 2008
How do I balance a Kenmore 70 series washing machine.
Wood laminate flooring is never a good idea in areas that can get wet often. But, that being said, there should be leveling feet on the washer which should allow you to get it stable on the floor, if that's what your problem is. If your problem is that the washer tends to walk around the room when in the spin cycle, well that is partially due to the fact that washers often vibrate when they spin, especially when spinning large, bulky objects like quilts and comforters, that the feet on the bottom of washer are smooth plastic, and that smooth plastic feet don't stay in one place to well on wood laminate floors.
Mar 04, 2015 | Kenmore Washing Machines
Leveled washer gets out of balance when load in spin cycle
A vibration problem is about the hardest thing to diagnose long distance but I will give you the most common things to look for.
Shipping brackets and materials not removed from the machine. You should be able to move the basket around easily by hand. Go over the installation instructions and make sure everything has been removed.
Leveling legs and lock nuts misadjusted or loose. You want the legs adjusted as low to the floor as possible. The higher it sits, the more movement it has.
Weak floor. If you can stomp the floor and have pictures rattle on the wall, you will have vibration problems with the washer. If it is on a laminate hardwood floor, you will have vibration problems. These floors have too much bounce for a washing machine.
The tub support to stiff causing too much vibration to be transferred to the cabinet or not allowing the tub/basket to return to the upright position so that it starts an out of balance spin. Put the washer into a cycle and let it agitate. Before it goes into a spin, open the lid and see if it is leaning awkwardly to one side. If the washer has some years on it, this may be your problem. If you remove the front panel you will see the thick washer the whole unit sits on. If it seems the unit is stiff , you may try spraying a LITTLE wd40 on the base it sits on so it slides easier, but just a little.
Check these things out and you should find your problem.
Thanks/Mike
Oct 24, 2007 | Washing Machines
Washer is out of balance in the dpin cycle since we installed a new floating floor in our laundry room. Have tried rubber feet for levelers and sticky pads to floor, nothing seems to help.
So, is the machine level and STABLE? The final step is to tilt the machine forward on to the two front feet. This allows the rear, SELF LEVELING legs to reset. Then set the machine back on all four feet.
Sometimes the real feet get jambed and will not release unless you pry them loose. In extreme cases the rear feet damage the plastic holder that they are in...
BUT, the tilt foreward and set back on rear legs works most every time.
May 01, 2011 | Washing Machines
My kenmore top loader always shakes acrosss the floor. I stop it during spin cycle and reujust the load. the machine is level on the floor and the feet are dialed in.
is there rubber on the bottom of the feet?also i've seen in laundry rooms at one time or another the vent line on the dryer popped off or had a hole in it and lint got on the floor and under the washer,it finds it's way under the feet,try tilting the washer back and with a steel brush or sand paper clean off the bottom of the feet and see if that helps,also clean the floor under the washer.you may have to replace the rubbers on the feet.good luck
Mar 28, 2011 | Kenmore 22422 Top Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
How do I balance a load. My front load GE washer seems to jump around a whole bunch.
In theory the front load washing machine is self balanced. The problem you are experiancing is most likely due to the machine being impropperly leveled on the floor. It is not only important to have the top of the machine level front to back, and side to side. It is also essential to have good pressure on all of the leveling feet of the machine.
Any side to side motion of the machine will be magnified if the feet don't share the load. (The weight of the machine and its contents.)
The easyest way to accomplish leveling the machine propperly is to put a level on the top of the machine on a flat surface from side to side, and turn each foot down untill it is leveled propperly by the back feet. be careful that you don't mess up the exhaust hose, gas line, ect while doing this.
Then put the level from front to back, and make slight adjustments to the front feet until it is level in both directions, and has equal pressure on both front feet. You can usually tell by the resistance the foot has to turning.
Then just run a load of laundry as usual. It should run great for a very long time, but need adjustments againeventually.
Presto.
Oct 28, 2010 | GE WSXH208A Front Load Washer
Washer doesn't sit level in new laundry room
A washing machine may wiggle, rattle or move across the floor. It is often accompanied by excessive, or loud noise. There can be several causes and the problem is worse with some units more than others.The most common cause is an unbalanced wash load. Open the lid/door, and attempt to redistribute the clothing to balance the weight. Heavy loads, especially things like comforters, are more likely to become unbalanced than small loads. If you do a lot of heavy loads, you should consider a heavy duty/large capacity washer when it comes time to replace your current unit. A washer must be level both from side to side as well as from front to back. Washing machines have adjustable feet to enable you to level them. See your manual on how to level your washing machine.The outer tub/basket, is supported by springs, pistons or counterweights to keep it balanced. The weight of all that water in a wash load requires a powerful balancing mechanism. If the balancing system becomes detached from one or more points, it will not be able to balance the load properly. Furthermore, even if everything appears to be in place, as the appliance ages, the springs or pistons/shock absorbers, may begin to wear out and not support as much weigh as needed.
In order to check properly for internal issues,unplug the washer and open the cabinet. Because of the variety of balancing mechanisms, you will have to inspect your machine to determine how it is balanced. Once you discover the mechanism, then inspect it for integrity. In the case of old parts that appear to be in working order, you may not be able to tell if they need to be replaced. They may be weak but appear to be in good condition. If no other solution resolves the problem, then replacing the balancing springs or other moving support parts may be the best action.Another common cause for excessive movement, or rocking, is the floor on which the washer sits. The washer is heavy and even more so when filled with water. Any floor, other than a concrete slab, will tend to pick up and amplify the vibrations from the machine.There are a couple things you can try. If you have access to the joists under the floor, you may be able to beef up the support. Another thing to try is placing a large sheet of plywood under the washer. It should be 3/4" or even 1" thick and as large as possible to distribute the weight. Use a sheet big enough for both the washer and dryer to sit on. If possible fasten the plywood to the existing floor.
May 23, 2010 | GE WSXH208A Front Load Washer
Machine shakes and walks
C.. check you securing springs to the drum/tub have not came off/snapped
Apr 08, 2010 | Magic Chef CAV2004A Top Load Washer
My Frigidaire Washer likes to walk around the laundry room while doing the spin cycle. It hasn't always done this. I had a repair guy over who checked out all the springs and everything and ended up...
Is this a front load? Check to make SURE that the shipping pins were removed completely. Thay can sometimes look as if they are and one has broken off(top-load)
Sep 13, 2009 | Frigidaire Washing Machines
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
