Question about Jenn-Air JCD2389G Side by Side Refrigerator
Water filter light
I have replaced an old water filter w/ a new one. Cannot figure out how to get the "replace filter" light to turn-off.
  • 487 Answers
To reset. hold dispense light and lock key pads on the dispenser control panel pushed in for 3 seconds until light flashes. This will reset it
Please rate me.
Posted on Apr 20, 2008
Replacing water filter on Maytag refrigerator model # MSW2273VEW00 Type 22MSSA. Purchased april 2012
read the service manual?
if you cant figure this out maybe you should
CALL A PROFESSIONAL
Dec 29, 2014 | Maytag Refrigerators
Where is the water filter on a 1997 side by side Roper
Do you have a manual for the refrigerator to check he same
Sep 08, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
I replaced the water filter and the light is still on. What should I do next.
Have you held down the reset button which is usally right on the front on the refrigirator. Please give your model to help you out more. I just have to hold down my filter icon and it disappeared.
Dec 14, 2014 | Samsung Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
Water filter replacement on a GE Profile Refrigerator
You should NOT have to turn the water off to replace the filter. I have the same refrigerator and it closes water line itself when you turn the filter and drop it down. If yours flooded, I can only imagne the valve that the filter opens when in place got stuck.
There is a valve on the wall behind your refrigerator which can be shutoff.
The old filter should be heavier as it would still have water in it. Turn them over one by so water can drain out. The one with the smallest amount of water should be the new one. I always use a sharpie and mark the filter with the install date... that way ou know when to replace and which is the old one.
Jun 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
No flow after filter change.
G E waterfilters , can be bad when new (all , not just G E ). Put your old one back in , if water flow was fine , and you replaced just because the light came on . Or , use the plastic bypass piece , which came with the refrig , when new . The replace light , works off time and/or usage times only . If you have good water flow and the cubes are normal size , don't change the filter when the light comes on , just reset the light . All "filter" companies , have found the way to sell more filters , the light on dispensors .
Sep 11, 2009 | GE Refrigerators
How do I replace the water filter in my Maytag Refrigerator it is a side by side with the ice maker in the freezer door. The light is on and I can't find my boodk
iF THE FILTER IS IN THE UPPER LEFT HAND CORNER OVER THE ICEMAKER. iIF YOU HAVE A REPLACEMENT FILTER ON HAND. YOU NEED TO TURN OFF THE WATER SUPPLY AT THE SOURCE. DISCONNECT THE VINYL TUBING AND LET IT DRAIN INTO A BUCKET OR ANY OTHER VESSEL. THEN YOU CAN TWIST THE WATER FILTER COVER COUNTERCLOCKWISE AND REMOVE THE OLD FILTER CARTRIDGE AND INSTALL THE NEW NEW ONE. THEN JUST REATTACH THE WATER SUPPLY LINE AND TURN ON THE WATER SOURCE. THERE SHOULD BE AIR AT FIRST THEN WATER SHOULD COME OUT OF THE WATER DISPENSER.
Jul 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
HAVE REPLACE THE FILTER, NO WATER OR ICE WHEN FILTER WAS OUT MADE ONE BATCH OF ICE THEN STOPPED NO NOTHING WATER IS ON NO KINKS IN HOSE WHAT IS WRONG THANKS ROSE
Try putting the old filter back in . Just because the " change filter " light comes on , does not mean to actually change the filter if your water dispensor is not just trickling out . If water was coming out fine before replacing filter , no need to replace it just because ot the indicator . I have found new filters which worked worse than the old filter . Just put the old filter back in and problem solved .
Jul 18, 2009 | GE Profile PSI23NCR Side by Side...
Water Filter removal/installation
Bought the filter replacement and read the instructions. Turn off ice maker and replace filter. Remove by turning 1/4 turn to the right. pull out old filter. Remove cover, slide off, replace cover by sliding on the new filter. Push new filter in to the holding, hold so cover is horizontal, push in and turn back clockwise till the cover is horizontal to the floor.
Feb 02, 2009 | Whirlpool GS6NBEXR Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
155 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
