Question about Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune gas dryer beeps.
I had a problem with dryer beeping and not operating, it was suggested to replace the control board which I did 4-6 weeks ago. The dryer started beeping again a week ago, BUT the dryer works fine. There are no codes that appear. Is there a reset sequence?
Thanx for your help,
Pete
  • Petelinda Apr 22, 2008
    As my first post stated I replaced the entire control board. Can I replace only the touch switch?
    Thanx for helping me thru this problem!
    Pete
  • judithleka Oct 20, 2008
    My dryer is a Maytag Neptune Dryer, model # MDE7550 AGW, for use in countries with 220 voltage. It also chirps and does not work. I have been advised to replace the control board, which is a very expensive solution here. Do you think simply replacing the trigger switch will do the job?
    Thanks for your help.
    Judy
    Novelist:
  • 184 Answers
NO RESETS OTHER THAN TO UNPLUG THE DRYER FOR 5 MINUTES, THEN RECONNECT POWER. ON ANY ELECTRONIC CONTROL, THIS WILL RESET THE CONTROL'S MICROCOMPUTER. IF THAT DOESN'T SOLVE THE PROBLEM, THE TOUCH SWITCH MAY BE FAULTY.
Posted on Apr 22, 2008
GE Dryer possible control board problem
Get another one with a good name and sell your old one on eBay and get a good price for it.
Jan 12, 2015 | GE Dryers
Have Duet front load dryer. When pressing Hold/start button, hear 3 fast beeps from the back of the unit, display flashes and dryer will not start. Any suggestions?
This is a common problem with the Duet and the solution is to replace the Motor Control Board (MCU). The control board has a short and the new control boards are revised to address this issue. Here is a link to the new control board.
Here is a copy of my service manual to help you replace the control board.
Good luck and keep me posted.Richard Roth
Oct 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Touch Panel Control Shorting Keys
I would check out the UK WHICH website.
Aug 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Kenmore oasis dryer cycle signal beeping constantly
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the unit first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer Only Works When The Start Button Is Held Down
Good news, I don't think it is the circuit board. Recheck to see if you put all the wires back on and securely. You may have the starter wires on backwards. The starter is a momentary contact switch and is used primarily to give power for just a split second to start the motor. Let me know how this turns out.
Dec 06, 2008 | Kenmore 63942 Dryer
Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
May 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Frigidaire LEQ2152ES Electric dryer
Just to verify does it also beep six times? This model has the actual pushbuttons. Press all buttons lightly and see if any release. Disengage button.
Nov 25, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Have to dry close twice on automatic, or once on timed. Random triple beeps.
Sounds like the drum belt has broken. It's connected around the drum and motor pulley. Without the belt turning the drum it will be near to impossible to dry the clothes, Hope this helps, Sea Breeze
Oct 28, 2007 | Whirlpool GEW9250 Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
740 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
