Question about Toshiba 51H93 51" Rear Projection HDTV
Horiz output failure repeatedly?
Where would i get circuit mod info?
  • 655 Answers
Click here to get manuall from toshiba.
Goto this page select your model
and download your manual.
Please post your feed-back
Thanks
Iqbal
Posted on Apr 15, 2008
  • Iqbal Husain
    Iqbal Husain Apr 15, 2008
    For direct download Click here;
    And please don't forget to rate this solution as fixya.
    Thanks
    Iqbal
    Brigadier General:
  • 3,614 Answers
Can you please provide the TV model and part #.
Thanks
Horiz deflectiion bad
if the transistor gets very hot in under 30 seconds the problem is in the driver circuit in front of it--open or off value cap is most common. 5 minutes is waiting too long---touch the face of transistor--can be mildly warm but not HOT.
Apr 10, 2012 | Televison & Video
Need info on mod kit for horiz output on Toshiba 51h93.
Do you have the part number, which kit do you need ?
Apr 21, 2008 | Televison & Video
I have two Sony KV-27FS120, they have the same problem, 4 blink, both have no vertical & horizontal drive from IC001 jungle chip, and Q505 horiz output blow. Circuits between them look good. I replace...
Check very carefully for cold solders on horiz. drive transformer also replace the electrolytic cap that shapes the horiz. drive signal - if you have a scope and manual compare the drive signal shape.
Some times using poor after market horiz o/p's also causes the problem - does the o/p heatsink get to hot to touch or does the horiz o/p blow immeadiatly?
Oct 19, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Picture goes into horizontal lines while watching then you shut it off for 10 min. or so and it resets it self
solder connections in horiz.drive/output circuit.also solder the flyback transformer.if only 10 minutes you need to solder in the
horiz.circuit area.get a magnify glass and usually will see hair line cracks around the
components.
Jul 17, 2009 | RCA TruFlat 27F520T 27" TV
Cost of horozontal circuit
In this set, the complete horiz circuit is not replaceable, unless you were to replace the complete mother board.
The flyback and various failed parts may be replaced as required. There are troubleshooting procedures to determine the defective parts. This is performed by following tests and diagnostics using the service manual as a reference, and using the various test instruments to follow up for readings. This takes proper training, instrumentation, and experience to perform.
The average cost can be in the area of $160 to $250 US to service the horiz output stage, depending on the types of failures.
Jerry G.
Jun 16, 2008 | Sony KV-36FS100 36" TV
Horizontal output transistor failure
check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Apr 09, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Horz. Output Transformer for a GE Mod#46GW945
Check this guys: //http://www.electronica-usa.com/
This guys may carry that part: //http://www.globalsemi.com/search.aspx
Jan 24, 2008 | GE 46GW945 46" Rear Projection Television
Tv trouble shooting
1)Check secondary fuse devices. 2)Check horiz output xistor=shorted? 3)replace w/equiv.or better part. 4)Check solder connects in horiz drive circuit. Replace small electrolytic filter cap in base circuit of horiz o/p==horiz drive xformer and xistor area,typically 1mf/160v,C531? 2b)not shorted==do step 4 anyway 5)still blinking?==check vert o/p,audio o/p and regulated o/p's
Oct 02, 2007 | JVC AV-A21M3U 21" TV
No picture has sound, then picture comes on after a while
check for a problem with the horiz.output circuit. maybe bad solder connections or the horiz.osc.
Sep 15, 2007 | RCA F27442 27" TV
Mitsubishi cs-35401television
HORIZONTAL FAILURE AND LINE DOWN THE SCREEN. REPLACE T5A1 LOCATED ON PCC-3-PCB. PT#349P145030(FOR CS-35401,CK-35402 ONLY) Hope this helps! Troy
Sep 11, 2007 | Televison & Video
Toshiba 51H93 51" Rear Projection HDTV Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
