Question about Dryers
Tumble dryer drum willnot revolve. not fitted with a trip switch that I can find. White Knight 37AW
  • 66 Answers
If you have the power and dryer is not truning. ck the belt it may came off or need to be replace.
Posted on Apr 14, 2008
I have a white knight dryer drive belt snapped how do i fit new one model cl382wv thanks
Posted on Dec 16, 2008
Its a fair bet the start capacitor for the motor is u/s. This
machine has an induction motor and needs a 'kick' to start, provided by said
capacitor.
You'll find it mounted on a bracket adjacent to the motor (accessible via
metal plate under machine) It's an 8 microfarad jobbie, available from your
local Electrolux sevice centre. Needless to say you must isolate machine
from mains and discharge any remaining charge in capacitor before attempting
to change it.
debbie
Posted on Jul 07, 2008
  • Dflybrd Jul 07, 2008
    hi again,i also have a white knight dryer,& my drum stopped spinning.but it does spin if i give the drum a gentle push though.i have just bought a capacitor from ebay for less than a fiver.if your drum moves when you gently push it,we did this with the lid off,then chances are it's definately the capacitor.hope this helps.
  • stevedyer196 Feb 22, 2012
    How do i know which wire goes to which terminal there are no markings
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My white knight tumble dryer wont start
Nothing works or drum fails to turn (tumble dryers)
Ensure that the power supply to the dryer is switched on, the timer is set to the desired drying time and the door is correctly closed. If you have a condenser model, also check that the bottle is empty and is fully pushed into the machine.
http://www.whiteknightrange.co.uk/whiteknight/faq.html
The first thing to establish when troubleshooting the clothes dryer is whether the dryer will start or not. If it won't, start by checking the outlet and the circuit breaker. Is the dryer plugged in or has it tripped the circuit breaker? If the breaker has been tripped, flip it back on and try the dryer again. The drum should turn without a problem.
If both plug and breaker are fine, you'll need to inspect the door switch as you continue to troubleshoot the tumble dryer. When you close the door on the dryer, a plastic peg should click and operate the switch which allows the dryer to work. The peg might be bent or broken, in which case it won't connect with the switch. You can try to straighten the peg, but if it's broken, you'll need to replace it. If the peg is fine, the switch has probably failed and will need to be replaced.
http://www.doityourself.com/stry/troubleshooting-a-clothes-dryer-drum-doesnt-tumble#b#ixzz3FOOQgtAT
Oct 06, 2014 | White Knight Press Genuine Tumble Dryer...
How to replace door handle on a White knight tumble?
quicker and easier to replace the door, cheaper in the long run.
Jul 23, 2014 | White Knight Press Genuine Tumble Dryer...
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Need instructions on how to use the White Knight Tumble Dryer Model No 031243215005
Hi Paula,
Think you might have the serial number, is there a number on the front of the dryer usually two numbers and 2 letters e.g. 37aw
Jun 10, 2009 | Dryers
How to fit new drive belt to white knight tumble dryer
YOU HAVE TO REMOVE BACK AND EASE REARWARD - THEN SLIP DRUM BELT IN FRONT OF DRUM THEN REASSEMBLE - NOT EASY TO EXPLAIN
Apr 05, 2009 | Dryers
Dryers Logo
564 people viewed this question
Top Dryers Experts
