Air conditional My air condition - Alasca MAC1210 shows H8 and it wont start or oprate what can i do please.
  • 236 Answers
Reset the error by disconnecting the supply for 10 sec. and " on " again, test the unit. If it wont work just call a tech, to fix the problem.
Posted on Apr 14, 2008
What does the message H8 mean?
Call tech support and they can give you all the info you need.
For Technical Support and Warranty Service Please Call (888) 876-5387 Or Write To: Soleus International Inc. 20035 E. Walnut Dr. N. City of Industry, CA 91789 USA www.soleusair.com
Sep 18, 2014 | Soleus LX-140 Portable Air Conditioner
Soleus gb-pac-08e4 h8
The unit is NOT pulling water from the air to cause this error, yes they pull moisture out of the air and over TIME fill with water. The problem is that the unit shows the H8 error even when empty. Worked for 2 months and now just keeps popping the H8 code, EVEN THOUGH IT IS EMPTY. Unfortunately sometime you find out after buying a product that it is not quality, that is the case with Soleusair. Bad company, Bad product.
Jun 17, 2012 | Soleus KFR-18 Air Conditioner
My truck is showing codes 171 and 174. Can you help
P0174 Generic Definition
Fuel Trim Bank Two Condition
- The ECM has detected a rich or lean air/fuel ratio condition on engine bank two
Probable Cause[s]
  1. If bank one and two are set together suspect a fuel pressure condition or MAF sensor fault
  2. Failed HO2S21
  3. Ignition misfire condition
  4. Fuel injector problem
  5. Engine mechanical condition
    P0171 Generic Definition
    Fuel trim bank one condition
    - The powertrain control module uses the oxygen sensor to calculate the air/fuel ratio of the engine. The computer has recognized a rich or lean condition on one engine bank only.
    Probable Cause[s]
    1. If bank one and two codes set together suspect fuel pressure or MAF (Mass Air Flow) Sensor
    2. Oxygen sensor defective
    3. Ignition misfire-repair
      Mar 05, 2011 | 1999 Chevrolet Silverado 1500
      Whirpool h8 error
      I'm not a technician, but I'll share how I solved my problem. My portable whirlpool a/c wasn't working and had the H8 error code. I drained the water that was accumulated inside it and it started working again.
      Dec 29, 2010 | Whirlpool ACP102PS Portable Air...
      My aspire one has virus wont let me do alt f10 says recovery is infected
      take good condition of oprating system cd which is preinstall in your pc
      you can check your oprating system on the back side on you laptop where windows product key is printed it 25 digits key
      run any oprating system cdwhich is mantioned on back buy from market or take it from your friend
      remember put 25 digit product key on back when cd ask for key your oprating system will geniun
      Jan 27, 2010 | Acer Aspire One PC Notebook
      1994 BMW 318i Air conditioning problem
      You need to check the blower motor in car ...
      Good luck..
      Jan 15, 2009 | 1994 BMW 3 Series
      Wall paper Settings
      The 3230 isn't able to show you what memory is actually being used, so it isn't giving you an accurate reading.
      Do you have a memory card installed? Copy some files over to your memory card and try it that way.
      Hope you solve your problem.
      Mar 13, 2008 | Nokia 3230
      Heating & Cooling Logo
      306 people viewed this question
      Top Heating & Cooling Experts
      Paul Carew
      Dan Webster
      Dan Webster
      Tim Whalen
