Question about Canon EOS Rebel 2000 with 28-80 lens 35mm Film Camera
Canon eos 2000 battery problem
Replaced batteries and battery icon still flashing. Had batteries tested and they are good. Cannot take photos or advance film. Camera will not function at all. Any suggestions without having to send it off. Short of buying a new camera, I need it repaired asap. Have a wedding to shoot in a month. Please Help!!!
  • 1 more comment
  • moherron Jul 03, 2008
    I'm having the same problem -- did you ever gat an response?
  • Anonymous Jul 28, 2008
    LOW BATTERY FLASHING. REPLACED WITH NEW ONES..NO DISPLAY. PUT OLD ONES BACK, LOW BATTERY, PUT SECOND NEW ONES IN, NO DISPLAY. NOW NO DISPLAY AT ALL. CAMERA DEAD. CLEANED CONTACTS. NOTHING WORKS. MADJAX
  • Anonymous Feb 10, 2009
    I have the same problem. The low battery light was flashing and I purchased new batteries. The new batteries didn't do anything. I bought new batteries again and yet nothing happened. Had a friend with THE same camera and took their batteries out of their WORKING camera and yet again, the low battery light continued to flash on mine.
    I'm still looking for answers. Any help would be nice.
  • 44 Answers
SOURCE: canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Posted on Dec 12, 2008
  • 4 Answers
SOURCE: batttery icon shows low battery even though new batteries are ins
I am not sure if this will address your problem but it is worth trying.
Make sure the record/playback mode switch is not in an intermediate position. Push it firmly all the way up. Also ensure that the mode button is not between clickstops. Then try to operate the camera
If that does not help, try the following. Take all the batteries out, including the lithium battery which keeps the clock going. Also take the SD memory card out. Leave the camera sit overnight.
Obtain new batteries - conventional alkaline AAs and a lithium type CR1220.
Next day, clean all the contacts for the AA batteries with a cotton-bud and contact cleaner or isopropyl alcohol. Let dry. Then insert the new lithium battery. Next insert the new AAs and try to turn the camera on.
If it works, insert the SD card. If it does not work then there is probably an internal problem and it should be serviced.
Posted on Feb 16, 2009
pontelemon
  • 538 Answers
SOURCE: WHEN I LOAD A ROLL OF FILM INTO MY CANON EOS 600,
Jammed Advance motor. Unfortunately, there is no way to reset it or fix externally. Will need service.
Posted on Apr 19, 2009
  • 6 Answers
SOURCE: Error 99 message keeps popping up
Try the following:
http://www.fixya.com/support/t1937149-err_99_in_canon_350d
This is a great post, as it already has alll of the relevant information that the canon reps will give you. It is step by step troubleshooting of this error.
Posted on Sep 02, 2009
  • 12 Answers
SOURCE: Busy light comes on when I start the camera
Had the same thing happen to me, took the batter and memory card out then tried to turn it on (With no batter nothing was going to happen) left it in the on position for an hour replaced the batter and turned it on. Which worked for me (problem has never come back).
Posted on Jan 14, 2010
Canon Speedlite 580ex ii - won't work with camera
Caroline, you should try to set the camera on "M" and the flash in 2nd curtain flash sync.
Or set flash in ATG wireless IR ETTL Slave modes and pop-up the flash on Canon EOS-70D.
Truly,
atdlee@netzero.com
Feb 08, 2014 | Canon SPEEDLITE 580EX TTL Flash
Low battery showing replacing batteries does not solve problem
The flashing low battery symbol is the way Canon film cameras showed that the camera has had an error and has stopped functioning. It can have multiple causes - but for a quick check remove the lens, turn off the camera and then turn it back on - see if the symbol stops flashing. A problem with the lens can also cause this problem (usually a failure of the aperture unit)
Dec 27, 2011 | Canon EOS 5000 35mm Film Camera
Saturday night my camera would not turn on--I charged the battery and reinstalled them turned the camera on and it will flash EOS on the display screen where it normally shows battery strength, etc. and...
When was the last time you changed the internal "watch" battery in the camera? that might need changed.
And a new lithium battery might be a good idea too. my camera stopped turning on this summer until I replaced both batteries.
Hope this helps!
Oct 18, 2010 | Canon Rebel XT / EOS 350D Digital Camera
EOS 30D - blue print light then dead
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom right of your computer screen or did you just yank out the cord?
Jan 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Canon EOS 1000D wont take photos, viewfinder flashes busy
Maybe you drop your battery and they have electronic components inside that could be spoiled, if is that the case, try to change the battery, it appeares to me that the ammount of current the battery is sending to the component is very low even thoe it seems to be fully charged that's why the camera is unable to display anything and the "busy" warning is blinking all the time, I hope you find this usefull.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel GII Battery Icon
Hey dafgatti,
According to the manufacturer if replacing the batteries with new ones doesn't resolve the issue then there is something wrong with the camera internally. You should have it looked at by an authorized service technician. You could bring it to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out to an authorized service center, or you could contact the manufacturer and they should be able to assist you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 25, 2008 | Cameras
After taking one photo, camera display blinks and can't turn off or take more pics
TIggertigger, allthough batteries have improved alot they still eventualy die, by the sounds of this proublem the battery has died for what ever reasen, try getting a new battery. If this does not help try a filmwere upgrade, for insturctions on how to do this please contact canon.
Jun 27, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
May 10, 2008 | Canon EOS Rebel T2 with 28-90 lens 35mm...
Eos Rebel 2000 battery problem
Send camera to me and I will advise you B4 repairs regarding cost etc. WWW.FLCAMERAREPAIR,COM Art Schneider
Oct 18, 2007 | Canon EOS-AE-1 35mm SLR Camera
Camera battery is dead and was just bought a week ago
If the contacts have been cleaned in the battery chamber, check the lower contact post - it's spring loaded and often gets stuck and doesn't make good contact with the battery. A little WD40 usually will free it up. Your batteries are probably still good.
Oct 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS Rebel 2000 with 28-80 lens 35mm Film Camera Logo
300 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
