Question about GE 30 in. JGP326 Gas Cooktop
Possible dead mouse inside?
Smells like a decomposing mouse.I took off the knobs and it got stronger.Also can smell it when you take off the round things off the gas part on the burner.Could a mouse have gotten in there and if so how do I open it up to get it out.I have the manual and there is no diagram.
  • Sandra29 Dec 08, 2008
    I have a Baumatic gas hob and have what we thought was a dead mouse under or behind the units beneath the hob ehich was causing a stink. We pulled out the base boards to search for the mouse, we even used a mirror to search behind the unit but NOTHING.
    Our conclusion is that it got into the bottom of the hob when it was still warm and became trapped as the hob cooled. Each time I use the hob the smell is appalling.
    Before I send for someone to dismantle the hob, can anyone confirm that it is indeed a mouse or is there some other cause for the smell?
    Scholar:
  • 150 Answers
Need more info, make and model
Posted on Apr 23, 2008
You smell gas after it is turned off. you do not smell gas if valve is off. The burners work but when turned off you can smell a hint of gas.
Hi, you have a leak some where an old trick of finding gas leaks was to use washing up liquid diluted if its possible in this case and when the washing liquid finds the leak it produces a soapy bubbles where the leak is .
Jan 23, 2016 | Cooktops
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
The left side of my cooktop shorted out. Initially popping sound and electrical burning smell. Now shorted out with loud popping sounds and large flash of red under the cooktop. Did not start a fire but...
What you had was a slow short - practically the same thing as in a welder: big and loud flame, localized and the amperage isn't that great. As such it's very possible that the breaker wasn't tripped, especially if you had a big one, over 30Amps.
No, you shouldn't even try to repair it, that unit is dead as a dodo.
Aug 24, 2010 | Jenn-Air JED8430 Electric Cooktop
High-pitched squeal/whistle noise from range
Noise went away by itself. No root cause found. Please remove this posting, thanks.
Dec 04, 2009 | Maytag MGC6430 Gas Cooktop
One gas cooktop does not light, no gas smell
Hello Liz. The most common reason for the problem you are experiencing is greasey dirt in the burner. Use a small brush, some fine wire and some degreaser to clean up the burner. Then let it dry overnight and try it again. If it still won't start, you will have to replace the ignitor.
Nov 28, 2009 | Thermador SGS36GS Gas Cooktop
Electric shock from cooktop, didn't trip breaker,
Where did you smell the smell was it from the fan switch. turn the power off and take the screw out of where the fan switch is and check the wires to the switch and the switch itself. sometimes the jennair cooktops have issues with that switch. let me know how it goes
Sep 20, 2009 | Jenn-Air JED8230 Electric Cooktop
Neff gas hob burner won't turn off
yes it is sad to say
Aug 23, 2017 | Cooktops
Thermador gas cooktop explosion
I would say that pop was one of you igniters.  either that or the stove is not installed correctly and when it gets warm, thermal expansion makes the metal pop.  I would say that I would use caution and discontinue its use.  Most problems with these need to fixed professionally.
Mar 04, 2009 | Thermador PC36 36 in. Gas Cooktop
Cooktop will not get hot
wire conections to ct from house wiring may be loose check conectors
Dec 24, 2008 | Jenn-Air JED8430 Electric Cooktop
Smoke coming from control knob
sounds like you have a bad (elemnet)infinite switch. turn off the power before something really shorts out, replaceing the switch requires uninstalleing hte cooktop from the cabinet , removing the glass top and replacing the switch. first seeing which one is damaged
Sep 15, 2007 | Thermador 31 in. CET304 Electric Cooktop
GE 30 in. JGP326 Gas Cooktop Logo
244 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
